My apologies if this has been asked before. I am using Ubuntu 16.04.3 desktop and would like to be able to output the contents (file names) of a directory into a single text file via terminal/cli.
I think when I used to use DOS, years back, went something like this: dir /w/p > file.txt ..think that was it, but simple and damn handy
Thank you for your time and help with my question
Sean S
The general command for listing directory contents in Linux is ls
LS(1)                            User Commands                           LS(1)
NAME
       ls - list directory contents
SYNOPSIS
       ls [OPTION]... [FILE]...
DESCRIPTION
       List  information  about  the FILEs (the current directory by default).
       Sort entries alphabetically if none of -cftuvSUX nor --sort  is  speci‐
       fied.
Probably the nearest equivalent to dir /w will be ls -C (the /p option - pause - doesn't really make sense when writing to a file). So
ls -C > file.txt
In fact, there's a dir command in Linux as well - so you could just do dir > file.txt
See Difference between 'dir' and 'ls' terminal commands?
steeldriver
  • 142,475
