I switched from Gnome/Unity to LXDE on my netbook because it has only 1 GB RAM. Now the Kile window has no menu bar. How does one get it back?
This does not affect all KDE applications - for example, Kate does have a menu bar.
In ~/.kde/share/config/kilerc, look for the section [KileMainWindow], and within that look for the line menubar=Disabled. Change Disabled to Enabled or delete this line.
Thanks to @fossfreedom for suggesting looking in ~/.kde/share/config/kilerc.
converted comment to answer
A similar issue was reported on ubuntuforums.
In this case it was reported against Kubuntu - so the observation that you have switched to LXDE perhaps is not the key issue here.
The resolution was to rename the file ~/.kde/share/config/kilerc.
This file will then be regenerated when you next start Kile.
This will result in your own customisation settings being lost but user-defined shortcuts are retained.
If you do not want to destroy your settings:
~/.kde/share/config/kilerc with an editor.[KileMainWindow].MenuBar=Disabled to MenuBar=Enabled.The location of kilerc on my PC is $XDG_CONFIG_HOME/kilerc. As mentioned in the other answers, go to this file and change menubar=Disabled to menubar=Enabled.
