I was trying to upgrade 14.04 when I started to get dependencies error.
I have read and tried many things to fix the problem, but I always end up getting the error for any of the commands such as:
$ sudo apt-get install --fix-broken --fix-missing
or
$ sudo apt-get update (or upgrade)
or
$ sudo apt-get -f install
also I have tried commands such as:
$ sudo apt-get --reinstall install locales
Or
$ Sudo apt-cache policy libc6* locale
Or
$ sudo dpkg --configure -a
Gives:
(Reading database ... 319648 files and directories currently installed.)
Preparing to unpack .../libc-bin_2.26-0ubuntu2_amd64.deb ...
dpkg: error processing archive /var/cache/apt/archives/libc-bin_2.26-0ubuntu2_amd64.deb (--unpack):
 triggers ci file contains unknown directive `interest-await'
Mike
Upgrading 14.04 to 17.10 isn't supported.
The package you are trying to install requires a more recent version of dpkg than the one you have. Try to download the .deb package from https://packages.ubuntu.com/artful/dpkg and install it using dpkg:
sudo dpkg -i dpkg_1.18.24ubuntu1_amd64.deb
(you may need to replace the file name and path). Maybe that works.
Consider doing a fresh install of 17.10.
