I have a program I'm trying to get running on an Ubuntu machine (I've previously run it only on CentOS), and when executing it I get:
error while loading shared libraries: libmysqlclient.so.16: cannot open shared object file: No such file or directory
If I do "locate libmysqlclient.so", I get only:
/usr/lib/x86_64-linux-gnu/libmysqlclient.so.18
/usr/lib/x86_64-linux-gnu/libmysqlclient.so.18.0.0
I've tried:
apt-get install libmysqlclient-dev
But this did not solve the problem, and I still don't appear to have libmysqlclient.so.16.
I also found a forum post somewhere where someone apparently solved this by installing the rpm MySQL-shared-compat-5.1.49-1.rhel5.x86_64.rpm, so I tried this but with no change in the result.
I don't know if this is relevant, but the program I'm trying to execute is 32-bit, and I gather my system doesn't have 32-bit support, so initially I was getting "no such file or directory", until I followed the advice on this page: No such file or directory? But the file exists!.
Any help would be very much appreciated. Thanks.
