I bought the Lenovo ThinkPad E580 without operating system and I am trying to install Ubuntu 16.04. Everything is working so far, except the WIFI is not. The strange thing is, that the internet is working when I plug in a LAN cable.
I think a wireless driver must be missing, but I can't figure out, which one I have to install. At the website of Lenovo it says that the Laptop should have the wireless adapter "Intel Dual Band Wireless 3165 AC". But I cant find that one.
$ lspci -nnk | grep -i net -A2
03:00.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller [10ec:8168] (rev 10)
Subsystem: Lenovo RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller [17aa:5068]
Kernel driver in use: r8169
Kernel modules: r816
$ sudo lshw -class network
*-network
description: Ethernet interface
product: RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
vendor: Realtek Semiconductor Co., Ltd.
physical id: 0
bus info: pci@0000:03:00.0
logical name: enp3s0
version: 10
serial: 8c:16:45:00:99:5e
capacity: 1Gbit/s
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix vpd bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=half firmware=rtl8168g-3_0.0.1 04/23/13 latency=0 link=no multicast=yes port=MII speed=10Mbit/s
resources: irq:128 ioport:c000(size=256) memory:f2304000-f2304fff memory:f2300000-f2303fff
$ lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 005: ID 06cb:00a2 Synaptics, Inc.
Bus 001 Device 004: ID 5986:2113 Acer, Inc
Bus 001 Device 006: ID 0bda:b023 Realtek Semiconductor Corp.
Bus 001 Device 002: ID 0e8f:00a7 GreenAsia Inc.
$ rfkill list all
0: tpacpi_bluetooth_sw: Bluetooth
Soft blocked: no
Hard blocked: no
1: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
$ dmesg | grep -i firmware
[ 0.169227] ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
[ 1.612093] i915 0000:00:02.0: Direct firmware load for i915/kbl_dmc_ver1_01.bin failed with error -2
[ 1.612095] i915 0000:00:02.0: Failed to load DMC firmware [https://01.org/linuxgraphics/downloads/firmware], disabling runtime power management.
[ 1.957908] [drm] Found UVD firmware Version: 1.79 Family ID: 16
[ 1.958925] [drm] Found VCE firmware Version: 52.4 Binary ID: 3
[ 3.777769] bluetooth hci0: Direct firmware load for rtl_bt/rtl8822b_config.bin failed with error -2
[ 3.777777] bluetooth hci0: Direct firmware load for rtl_bt/rtl8822b_fw.bin failed with error -2
[ 3.778662] bluetooth hci0: Direct firmware load for rtl_bt/rtl8822b_config.bin failed with error -2
[ 3.778668] bluetooth hci0: Direct firmware load for rtl_bt/rtl8822b_fw.bin failed with error -2
[ 7.428180] psmouse serio2: trackpoint: IBM TrackPoint firmware: 0x10, buttons: 3/3
