I am on Ubuntu 17.10 I have downloaded a program for Linux, unzipped it and found it has no README, INSTALL or config folder. Hence, to make it runnable from the prompt I followed this: Install tar.gz , but no configure folder on install file
What I would like also to do, however, is to associate some extensions to the binary that I installed. As you would do by right-clicking on an extension, select "Open With Other Application" and selecting the app to run it. Unfortunately, the app I have installed is not listed in Ubuntt's list of applications.
Is there any way in which I can make the binary run every time I double-click on a file with a particular extension?
Bonus: may I have the app popping up in the GNOME app menu? (as if it was installed from the Software center or apt-get)
The program is Gephi (v 0.9.2)
Did you follow the installation process from the Gephi website ?
https://gephi.org/users/install/
If you have java installed, you just have to use the command
./bin/gephi
from the folder where you untar the file
you can also just double click on this same file from the file manager
Félicien
  • 1,203
