Is there a way to increase the default amount of history reverse-i-search (CTRL+R) keeps? In Ubuntu 16.04, it doesn't seem to have a very long "memory", sometimes even commands from yesterday are already gone from its history, ie. will not appear even after cycling through all entries with repeated CTRL+R.
I'm using Terminator as the console.
There is no time limit but rather a line or size limit on the history of the commandline.
You can modify that in your ~/.bashrc
export HISTSIZE=500000
export HISTFILESIZE=500000
Would mean a "memory" of 500.000 lines in your history, both currently (HISTSIZE) and written to your history file (HISTFILESIZE).
However, keep in mind that the file is only written when you exit a terminal.
You can reverse-i-search your commands in the same terminal, before the history is written to the history file, but cannot find your commands in any new terminals before you have not exited the original one!
Robert Riedl
  • 4,401
It is really easy, just change your HISTSIZE and HISTFILESIZE variables in you .bashrc
HISTSIZE=-1
HISTFILESIZE=-1
In bash 4.3 and later you can also use HISTSIZE=-1 HISTFILESIZE=-1 to set it to be unlimited.
Consider that HISTSIZE is the number of lines or commands that are stored in memory in a history list while your bash session is ongoing.
HISTFILESIZE is the number of lines or commands that (a) are allowed in the history file at startup time of a session, and (b) are stored in the history file at the end of your bash session for use in future sessions.
Take a look at this link
Regards,
The size of the history is specified with the two variables HISTSIZE (history of a single terminal session, saved in RAM) and HISTFILESIZE (size of the history file, usually ~/.bash_history). This size is set in number of lines in your ~/.bashrc file, e.g.:
HISTSIZE=1000
HISTFILESIZE=10000
This saves 1000 lines (= commands) per terminal session and 10000 in the history file.
The reverse-i-search searches the history of the current session as well as the history file, but it can't include commands from other sessions that are still opened.
Further reading:
dessert
  • 40,956
