Might have been asked previously, but I can't find a link. How do I make a bunch of commands run as root on startup without having to open the terminal or entering the password?
One way you can try it is by adding your commands to the /etc/crontab file with the @reboot command.
If you run the following command it will load up the file in an editor so you can add the line(s)
sudoedit /etc/crontab
Then how I did it was like so:
# m h dom mon dow user  command
17 *    * * *   root    cd / && run-parts --report /etc/cron.hourly
25 6    * * *   root    test -x /usr/sbin/anacron || ( cd / && run-parts --repo$
47 6    * * 7   root    test -x /usr/sbin/anacron || ( cd / && run-parts --repo$
52 6    1 * *   root    test -x /usr/sbin/anacron || ( cd / && run-parts --repo$
@reboot         root    /home/terrance/cb_update.bsh
05 1    * * *   root    /home/terrance/cb_update.bsh
As you can see my second to last line starts every time the system restarts @reboot then as the root user with my command of /home/terrance/cb_update.bsh. The last line starts at 01:05 in the morning everyday running that script as the root user.
Hope this helps!
Terrance
  • 43,712
