I recently found out that reboot works just as well as sudo reboot, from what I can tell. However, in a lot of instances, I see people saying to sudo reboot. Why is this? Are they the same, and just personal preference? Or are they different? Does sudo reboot do more than reboot?
- 40,956
- 923
On Ubuntu 14.10 and older, sudo is required.
The introduction of Systemd in 15.04 changed the way Ubuntu handles shutdown and reboot:
When a single user is logged in,
sudoisn't necessary. When more than one user is logged in thensudois required.Applications can inhibit
shutdownandreboot. You override these inhibitions withsudo.A single user logged in via
sshstill requiressudo.
- 68,493
On my 14.04 machine, when I (as a normal user) type reboot, I get
reboot: Need to be root
That is the difference.
As Terrance pointed out in the comments, it works differently on later systems than mine. So you are probably seeing old writeups and/or users (like me) who have been habituated to typing sudo reboot!
- 24,696
sudo rebootis used in tutorials / how-tos for compatibility reasons
While reboot might work
- if you are root or
- if you are on a host with
systemdand - if no applications are blocking a reboot
sudo reboot will "always"* work, regardless of
- whether you are root
- whether there are other users logged in
- whether there are applications blocking
- whether init is systemd, System V, Upstart, whatever
* Well, it will certainly try - short of there being some kernel processes that are blocking/misbehaving it should work.
- 72,312
- 4,401
For myself many times if I type reboot it won't let me due to inhibitors from Chrome when watching YouTube and other opened tabs. So I'm forced to use sudo reboot--a bigger hammer.
This in Ubuntu 16.04
- 105,762
Thanks for the discussion, I'm glad to understand this now!
As Terrance mentioned, in version 15.04, they switched from Upstart to Systemd for the commands. This change means that reboot no longer requires root privileges.
As for why the *nix community instructs to sudo reboot, there are a few potential reasons:
- Habit - People were so used to having to
sudo rebootto reboot, they continue to do it despite the fact it is not needed Non-updated users - The people instructing to
sudo rebootare on versions of Ubuntu lower than 15.04, or other distros that use Upstart for commands.Compatibility - This is what seems the most plausible to me: people are instructing to
sudo rebootbecause it is guaranteed to reboot across all *nix systems, no matter what.
Additional note: from user535733's answer:
The introduction of systemd in 15.04 changed the way Ubuntu handles shutdown and reboot:
sudoisn't necessary. When more than one user is logged in, thensudois required.Applications can inhibit shutdown and reboot. You override these inhibitions with
sudo.
- 923
