I've been trying to set up an Ubuntu 16.04 partition on my MacBook Pro (2017). I've created a 100GB partition for it (diskutil below). However when I try to install Ubuntu from my USB disk image, the installer can only detect the USB hard drive - it can't see the internal drive. Same problem arises if I try fdisk -l. Any help or advice would be much appreciated!
 /dev/disk0 (internal):
 #:                       TYPE NAME                    SIZE       IDENTIFIER
 0:      GUID_partition_scheme                         251.0 GB   disk0
 1:                        EFI EFI                     314.6 MB   disk0s1
 2:                 Apple_APFS Container disk1         150.0 GB   disk0s2
 3:       Microsoft Basic Data UbuntuPart              100.0 GB   disk0s3
 /dev/disk1 (synthesized):
 0:      APFS Container Scheme -                      +150.0 GB   disk1
                          Physical Store disk0s2
 1:                APFS Volume Macintosh HD            108.2 GB   disk1s1
 2:                APFS Volume Preboot                 21.3 MB    disk1s2
 3:                APFS Volume Recovery                509.8 MB   disk1s3
 4:                APFS Volume VM                      1.1 GB     disk1s5
 /dev/disk2 (external, physical):
 0:      GUID_partition_scheme                        *16.0 GB    disk2
 1:                        EFI EFI                     209.7 MB   disk2s1
 2:       Microsoft Basic Data UBUNTU                  15.8 GB    disk2s2
 [X:~]$ diskutil info /dev/disk0s3
    Device Identifier:        disk0s3
    Device Node:              /dev/disk0s3
    Whole:                    No
    Part of Whole:            disk0
    Volume Name:              UbuntuPart
    Mounted:                  Yes
    Mount Point:              /Volumes/UbuntuPart
    Partition Type:           Microsoft Basic Data
    File System Personality:  ExFAT
    Type (Bundle):            exfat
    Name (User Visible):      ExFAT
    OS Can Be Installed:      No
    Media Type:               Generic
    Protocol:                 PCI-Express
    SMART Status:             Not Supported
    Volume UUID:              D571AF1C-6074-3F47-AF60-B2987240331B
    Disk / Partition UUID:    036C0F0D-3771-4562-A55F-67642719B407
    Disk Size:                100.0 GB (99998498816 Bytes) (exactly 195309568 512-Byte-Units)
    Device Block Size:        4096 Bytes
    Volume Total Space:       100.0 GB (99994304512 Bytes) (exactly 195301376 512-Byte-Units)
    Volume Used Space:        9.6 MB (9568256 Bytes) (exactly 18688 512-Byte-Units) (0.0%)
    Volume Available Space:   100.0 GB (99984736256 Bytes) (exactly 195282688 512-Byte-Units) (100.0%)
    Allocation Block Size:    131072 Bytes
    Read-Only Media:          No
    Read-Only Volume:         No
    Device Location:          Internal
    Removable Media:          Fixed
    Solid State:              Yes
I think I finally figured this out...
The NVMe storage used in the newer MacBooks isn't supported in the versions of the Linux kernel currently used in most distributions. This support wasn't added until kernel version 5.1.5, which won't be packaged with Ubuntu until version 19.10 (currently in beta using kernel version 5.2.0).
Right now the options seem to be:
  • Make your own bootable image of your distro of choice using a kernel version of 5.1.5 or higher
  • Used a pre-patched version of a distro (example)
  • Wait for 19.10
Luke
  • 61
