The error:
sudo apt-get install python-pip
E: Could not get lock /var/lib/dpkg/lock - open (11: Resource temporarily unavailable)
E: Unable to lock the administration directory (/var/lib/dpkg/), is another process using it?
13dimitar
  • 955
Probably you issued the command when the system was already running an update of some software (automatically or not). Retry when you are sure no update takes place.
-1
If the problem persists (maybe after rebooting) you can remove the file
$ sudo rm -f /var/lib/dpkg/lock
