I just partitioned my windows machine and installed a fresh Ubuntu 16.04 on the partition with dual boot.
Unfortunately, the wifi doesn't seem to work - no networks are visible even though I'm in range of my home wifi. Also, I don't have access to a wired connection.
I'm 100% noob, but trying what I can. After some googling I found this link for linux support for wireless adapters and I figured I might need to install additional drivers? So I downloaded the driver from that link, which they said I could just put in /lib/firmware, which I proceeded to do...
Doing dmesg, I see there's a bunch of ugly errors:
[ 0.000000] [Firmware Bug]: TSC_DEADLINE disabled due to Errata; please update microcode to version: 0xb2 (or later)
[ 0.102148] ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
[ 2.224789] [drm] Finished loading DMC firmware i915/skl_dmc_ver1_26.bin (v1.26)
[ 3.514413] psmouse serio2: trackpoint: IBM TrackPoint firmware: 0x0e, buttons: 3/3
[ 10.833905] iwlwifi 0000:04:00.0: Direct firmware load for iwlwifi-8000C-33.ucode failed with error -2
[ 10.833919] iwlwifi 0000:04:00.0: Direct firmware load for iwlwifi-8000C-32.ucode failed with error -2
[ 10.833928] iwlwifi 0000:04:00.0: Direct firmware load for iwlwifi-8000C-31.ucode failed with error -2
[ 10.833937] iwlwifi 0000:04:00.0: Direct firmware load for iwlwifi-8000C-30.ucode failed with error -2
[ 10.833946] iwlwifi 0000:04:00.0: Direct firmware load for iwlwifi-8000C-29.ucode failed with error -2
[ 10.833954] iwlwifi 0000:04:00.0: Direct firmware load for iwlwifi-8000C-28.ucode failed with error -2
[ 10.833962] iwlwifi 0000:04:00.0: Direct firmware load for iwlwifi-8000C-27.ucode failed with error -2
[ 10.833970] iwlwifi 0000:04:00.0: Direct firmware load for iwlwifi-8000C-26.ucode failed with error -2
[ 10.833978] iwlwifi 0000:04:00.0: Direct firmware load for iwlwifi-8000C-25.ucode failed with error -2
[ 10.833986] iwlwifi 0000:04:00.0: Direct firmware load for iwlwifi-8000C-24.ucode failed with error -2
[ 10.833995] iwlwifi 0000:04:00.0: Direct firmware load for iwlwifi-8000C-23.ucode failed with error -2
[ 10.834003] iwlwifi 0000:04:00.0: Direct firmware load for iwlwifi-8000C-22.ucode failed with error -2
[ 10.834005] iwlwifi 0000:04:00.0: no suitable firmware found!
[ 10.834012] iwlwifi 0000:04:00.0: check git://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git
Doing lshw
*-network UNCLAIMED
description: Network controller
product: Wireless 8260
vendor: Intel Corporation
physical id: 0
bus info: pci@0000:04:00.0
version: 3a
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress cap_list
configuration: latency=0
resources: memory:f1000000-f1001fff
*-network
description: Ethernet interface
product: Ethernet Connection I219-LM
physical id: 1f.6
bus info: pci@0000:00:1f.6
logical name: enp0s31f6
version: 21
serial: c8:5b:76:b1:32:d0
capacity: 1Gbit/s
width: 32 bits
clock: 33MHz
capabilities: pm msi bus_master cap_list ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=e1000e driverversion=3.2.6-k firmware=0.13-3 latency=0 link=no multicast=yes port=twisted pair
resources: irq:122 memory:f1100000-f111ffff
I imagine the UNCLAIMED there means something is going wrong with talking to the wireless device?
Doing lsusb:
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 003: ID 04f2:b52c Chicony Electronics Co., Ltd
Bus 001 Device 002: ID 058f:6387 Alcor Micro Corp. Flash Drive
If there's anything else I can try, please holler at me in the comments! (I need to reboot into Ubuntu every time I want to try something, and write text to a flash drive...)
