In a recent reboot of Ubuntu, which failed, I get the message to run fsck manually. How do I do so. I may have a bad HD sector, and it may be easier to reinstall Ubuntu. I'm a newbie, so bear with me.
Asked
Active
Viewed 2.3k times
Note: For 18.04 and newer, see my new instructions.
To check the file system on your Ubuntu partition...
- boot to the GRUB menu
- choose Advanced Options
- choose Recovery mode
- choose Root access
- at the # prompt, type
sudo fsck -f / - repeat the
fsckcommand if there were errors - type
reboot
If for some reason you can't do the above...
- boot to a Ubuntu Live DVD/USB
- start
gpartedand determine which /dev/sdaX is your Ubuntu EXT4 partition - quit
gparted - open a
terminalwindow - type
sudo fsck -f /dev/sdaX# replacing X with the number you found earlier - repeat the fsck command if there were errors
- type
reboot
I'm a little late, but if anyone else reaches this thread, here's what worked for me:
The error screen said something about an orphaned linked list at dev/mmcblk0p2 and that I had to run fsck manually. The simple solution is to do exactly what it says: run fsck on the corrupted filesystem.
fsck /dev/mmcblk0p2
This will prompt you through the fixing of the filesystem easily and smoothly.
Pilot6
- 92,041
christian_js
- 606
