I'm logged in to my VPS through an SSH tunnel and have Apache installed on the server. Apache appears healthy and running.
sudo systemctl status apache2
● apache2.service - LSB: Apache2 web server
Loaded: loaded (/etc/init.d/apache2; bad; vendor preset: enabled)
Drop-In: /lib/systemd/system/apache2.service.d
└─apache2-systemd.conf
Active: active (running) since Thu 2018-02-08 20:20:51 UTC; 1 day 16h ago
Docs: man:systemd-sysv-generator(8)
Process: 34352 ExecReload=/etc/init.d/apache2 reload (code=exited, status=0/SUCCESS)
CGroup: /system.slice/apache2.service
├─20407 /usr/sbin/apache2 -k start
├─34370 /usr/sbin/apache2 -k start
└─34371 /usr/sbin/apache2 -k start
I'd like to do a simple test in the shell in order to visibly see the It Works! default message.
I run
/var/www/html$ http://6.5.4.2
only receive:
-bash: http://6.5.4.2: No such file or directory
Any ideas?
Thanks in advance.
