I use the following code at the end of one of my scripts to tally up the number of files I have processed and moved into that directory.
# Report on Current Status
echo -n "Cropped Files: "
ls "${Destination}" | wc -l
My problem lies with how I handle duplicate files. As of right now, I check for the file's presence first (as my script is destructive in nature to the source files I am processing). If it senses a file of that name already processed, I alter the filename as follows.
Duplicate file: foo.pdf
Changed name: foo.x.pdf
If there is a foo.x.pdf, then I rename again to foo.xx.pdf. Repeat as necessary. I intend to go in later and evaluate each 'version' and select the best one to keep on hand. But herein lies my problem. I would like to count the number of files that do not contain .x. .xx. and so on. How do I strip these out of the ls output so wc -l can count the unique files only?
TL;DR: How do I get the count of files in a given directory that do not contain a given substring in their filename?
