I have a problem that I'm trying to solve for a long time. I'm using Ubuntu 16.04 dual boot with Windows 10:
When I'm using several tabs in Firefox or Chromium, I see significant memory usage. One tab takes up to 500MB of RAM and when it gets to 3,7GB Ram usage my pc freeze and only what I can do is hard-reset my pc.
I've tried several things to solve this problem:
  • Disabled all add-ons in Firefox (Firefox version is 58)
  • Update kernel to 4.13
  • Disabled "Use hardware acceleration when available" and made more thing to optimize Firefox performance
  • Tried to use Firefox in safe mode
  • Increased swapping vm.swappiness=10 and swap to 8gb
I have a total 4GB of RAM. I never had that problem using Windows before only this happens on Ubuntu.
free --human output:
              total        used        free      shared  buff/cache   available
Mem:           3,7G        1,2G        1,2G         50M        1,3G        2,2G
Swap:          8,1G          0B        8,1G
swapon output
Filename            Type        Size     Used   Priority
/swapfile           file        8388604     0         -1
/dev/sda5           partition   102396      0         -2
uname -r output
4.13.0-32-generic
What else can I try to solve the problem?
Fabby
  • 35,017
Viktor
  • 151
What you're running into is called swapping: You're out of RAM and the kernel swaps unused programs to disk. Setting swappiness to 10 just means the kernel is swapping later rather than earlier (as the default is 60).
As swapping to disk is 1000 times slower than using RAM it just looks like your PC is freezing, but it's not.
You have a few options:
  • Don't use Chromium: that's a real memory hog; stick to Firefox only!
  • Use AdBlock+ (advertisements eat memory too)
  • Use NoScript (only allow the scripts you need on the pages you need)
  • Use fewer tabs
  • set swappiness back to 60 and be patient when swapping
and the easiest solution of all:
  • Buy more RAM
(also the most expensive)
Fabby
  • 35,017
