I want to use Ubuntu on my external hard drive by shrinking into a partition. I use both SSD and external hard drive on my PC and both are installed Windows 10. My external hard drive has 931 GB available capacity and I shrink its volume as 150 GB unallocated and 781 GB NTFS formatted partitions. Does that mean this unallocated part also have NTFS format or not?
Also, When I configure boot options from BIOS. I see a Partition 1 when I use my Ubuntu installed USB stick. If I choose Partition 1, would it also install Ubuntu on my 781 GB NTFS formatted partition? To make it clear I am sharing my disk management page for my PC.
Any help would be appreciated.
Özge
When you start installing Ubuntu it will ask you a option like this- Installation Type
You will be asked here if you want to erase the disk or do something else.Select something else.Here select the unallocated partition of 150 GB(in your case). Partitions
This way data from the disk will not be deleted(in your case 781 GB).
In response to your other question-No,unallocated part does not have NTFS format until you format it as NTFS or some other file system.
