I want to install playonlinux on Ubuntu 17.10, I saw this question and its answer, But after sudo apt-get install playonlinux I am getting the following error:
Reading package lists... Done
Building dependency tree
playonlinux : Depends: curl
E: Unable to correct problems, you have held broken package
What can I do to fix this and get playonlinux installed?
sudo apt-get update :
arya@arya:~$ sudo apt-get update
Get:1 http://ppa.launchpad.net/noobslab/apps/ubuntu artful InRelease [15.4 kB]
Ign:2 http://dl.google.com/linux/chrome/deb stable InRelease
Hit:3 http://archive.ubuntu.com/ubuntu artful InRelease
Hit:4 http://dl.google.com/linux/chrome/deb stable Release
Get:6 http://ppa.launchpad.net/noobslab/apps/ubuntu artful/main i386 Packages [1,572 B]
Get:7 http://ppa.launchpad.net/noobslab/apps/ubuntu artful/main amd64 Packages [1,560 B]
Get:8 http://ppa.launchpad.net/noobslab/apps/ubuntu artful/main Translation-en [1,160 B]
Fetched 19.7 kB in 4s (4,087 B/s)
sudo apt-get upgarde :
arya@arya:~$ sudo apt-get upgrade
Calculating upgrade... Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
apt policy playonlinux curl libcurl3 :
arya@arya:~$ apt policy playonlinux curl libcurl3
playonlinux:
Installed: (none)
Candidate: 4.2.12-1
Version table:
4.2.12-1 500
500 http://archive.ubuntu.com/ubuntu artful/multiverse amd64 Packages
500 http://archive.ubuntu.com/ubuntu artful/multiverse i386 Packages
curl:
Installed: (none)
Candidate: 7.55.1-1ubuntu2
Version table:
7.55.1-1ubuntu2 500
500 http://archive.ubuntu.com/ubuntu artful/main amd64 Packages
libcurl3:
Installed: 7.55.1-1ubuntu2.3
Candidate: 7.55.1-1ubuntu2.3
Version table:
*** 7.55.1-1ubuntu2.3 100
100 /var/lib/dpkg/status
7.55.1-1ubuntu2 500
