Wifi driver not being detected on Ubuntu 14.04.5. device: hp 15 bw096au powered by AMD a6-9220.
sudo dkms status
Output:
bcmwl, 6.30.223.248+bdcom, 4.4.0-112-generic, x86_64: installed
r8168, 8.037.00: added
rtl8723de, 5.1.1.8_21285.20171026_COEX20170111-1414: added
rtlwifi-new, 0.10~trusty, 4.4.0-112-generic, x86_64: installed
sudo dkms install rtl8723de/5.1.1.8_21285.20171026_COEX20170111-1414
Output:
Kernel preparation unnecessary for this kernel.  Skipping...
Building module: cleaning build area.... 'make' all KVER=4.4.0-112-generic.....(bad exit status: 2) ERROR (dkms apport): binary package for rtl8723de: 5.1.1.8_21285.20171026_COEX20170111-1414 not found Error! Bad return status for module build on kernel: 4.4.0-112-generic (x86_64) Consult /var/lib/dkms/rtl8723de/5.1.1.8_21285.20171026_COEX20170111-1414/build/make.log for more information.
modinfo rtl8723de | grep file
Output:
modinfo: ERROR: Module rtl8723de not found.
rfkill list all
Output:
0: hci0: Bluetooth
    Soft blocked: no
    Hard blocked: no
sudo modprobe rtl8723de
Output:
modprobe: FATAL: Module rtl8723de not found.
sudo dkms remove rtlwifi-new/0.10~trusty
Output:
Error! Invalid number of parameters passed.
Usage: `remove <module>/<module-version> --all`
   or: `remove <module>/<module-version> -k <kernel-version>`
Output:
make Output: make ARCH=x86_64 CROSS_COMPILE= -C /lib/modules/4.4.0-112-generic/build M=/home/kazi/rtl8723de modules make[1]: Entering directory /usr/src/linux-headers-4.4.0-112-generic' CC [M] /home/kazi/rtl8723de/core/rtw_cmd.o In file included from /home/kazi/rtl8723de/include/drv_types.h:32:0, from /home/kazi/rtl8723de/core/rtw_cmd.c:22: /home/kazi/rtl8723de/include/osdep_service.h:41:33: fatal error: linux/sched/signal.h: No such file or directory #include <linux/sched/signal.h> ^ compilation terminated. make[2]: *** [/home/kazi/rtl8723de/core/rtw_cmd.o] Error 1 make[1]: *** [module/home/kazi/rtl8723de] Error 2 make[1]: Leaving directory /usr/src/linux-headers-4.4.0-112-generic' make: *** [modules] Error 2 output for `cat /var/lib/dkms/rtl8723de
5.1.1.8_21285.20171026_COEX20170111-1414/build/make.log`                   DKMS make.log for rtl8723de-5.1.1.8_21285.20171026_COEX20170111-1414 for kernel 4.15.0-20-generic (x86_64)
Sat May 12 02:13:04 IST 2018
make ARCH=x86_64 CROSS_COMPILE= -C /lib/modules/4.15.0-20-generic/build M=/var/lib/dkms/rtl8723de/5.1.1.8_21285.20171026_COEX20170111-1414/build  modules
make[1]: Entering directory '/usr/src/linux-headers-4.15.0-20-generic'
Makefile:976: "Cannot use CONFIG_STACK_VALIDATION=y, please install libelf-dev, libelf-devel or elfutils-libelf-devel"
  CC [M]  /var/lib/dkms/rtl8723de/5.1.1.8_21285.20171026_COEX20170111-1414/build/core/rtw_cmd.o
In file included from /var/lib/dkms/rtl8723de/5.1.1.8_21285.20171026_COEX20170111-1414/build/include/osdep_service.h:41:0,
                 from /var/lib/dkms/rtl8723de/5.1.1.8_21285.20171026_COEX20170111-1414/build/include/drv_types.h:32,
                 from /var/lib/dkms/rtl8723de/5.1.1.8_21285.20171026_COEX20170111-1414/build/core/rtw_cmd.c:22:
/var/lib/dkms/rtl8723de/5.1.1.8_21285.20171026_COEX20170111-1414/build/include/osdep_service_linux.h: In function ‘_init_timer’:
/var/lib/dkms/rtl8723de/5.1.1.8_21285.20171026_COEX20170111-1414/build/include/osdep_service_linux.h:287:8: error: ‘_timer {aka struct timer_list}’ has no member named ‘data’
  ptimer->data = (unsigned long)cntx;
/var/lib/dkms/rtl8723de/5.1.1.8_21285.20171026_COEX20170111-1414/build/include/osdep_service_linux.h:288:2: error: implicit declaration of function ‘init_timer’; did you mean ‘_init_timer’? [-Werror=implicit-function-declaration]
  init_timer(ptimer);
  _init_timer
In file included from /var/lib/dkms/rtl8723de/5.1.1.8_21285.20171026_COEX20170111-1414/build/include/drv_types.h:32:0,
/var/lib/dkms/rtl8723de/5.1.1.8_21285.20171026_COEX20170111-1414/build/include/osdep_service.h: In function ‘thread_enter’:
/var/lib/dkms/rtl8723de/5.1.1.8_21285.20171026_COEX20170111-1414/build/include/osdep_service.h:369:2: error: implicit declaration of function ‘allow_signal’; did you mean ‘do_signal’? [-Werror=implicit-function-declaration]
  allow_signal(SIGTERM);
  do_signal
/var/lib/dkms/rtl8723de/5.1.1.8_21285.20171026_COEX20170111-1414/build/include/osdep_service.h: In function ‘flush_signals_thread’:
/var/lib/dkms/rtl8723de/5.1.1.8_21285.20171026_COEX20170111-1414/build/include/osdep_service.h:391:6: error: implicit declaration of function ‘signal_pending’; did you mean ‘timer_pending’? [-Werror=implicit-function-declaration]
  if (signal_pending(current))
      timer_pending
/var/lib/dkms/rtl8723de/5.1.1.8_21285.20171026_COEX20170111-1414/build/include/osdep_service.h:392:3: error: implicit declaration of function ‘flush_signals’; did you mean ‘do_signal’? [-Werror=implicit-function-declaration]
   flush_signals(current);
   do_signal
cc1: some warnings being treated as errors
scripts/Makefile.build:332: recipe for target '/var/lib/dkms/rtl8723de/5.1.1.8_21285.20171026_COEX20170111-1414/build/core/rtw_cmd.o' failed
make[2]: *** [/var/lib/dkms/rtl8723de/5.1.1.8_21285.20171026_COEX20170111-1414/build/core/rtw_cmd.o] Error 1
Makefile:1552: recipe for target '_module_/var/lib/dkms/rtl8723de/5.1.1.8_21285.20171026_COEX20170111-1414/build' failed
make[1]: *** [_module_/var/lib/dkms/rtl8723de/5.1.1.8_21285.20171026_COEX20170111-1414/build] Error 2
make[1]: Leaving directory '/usr/src/linux-headers-4.15.0-20-generic'
Makefile:1884: recipe for target 'modules' failed
You have a few instances where a dkms module was added, but not fully installed.
sudo dkms remove rtl8723de/5.1.1.8_21285.20171026_COEX20170111-1414 --all
If there are any errors after any of these commands, STOP and post them here. Do not proceed until these errors are fixed.
If there are no errors, then do:
sudo rm -rf rtl8723de
git clone -b 4.10-down https://github.com/jeremyb31/rtl8723de.git
sudo dkms add ./rtl8723de
Then reboot.
Again, if there is any error, stop and tell us so we can fix it first.
chili555
  • 61,330
