-1
In the past days, I used VLC to watch video tutorials. But, occasionally, the video couldn't play correctly and had screen stuck problems. I thought that I perhaps needed to update my system and the software. So I used the command:
sudo apt upgrade
trying to fix problem, but, unfortunately my computer also held those problems. The system and VLC are both on the last version.
Last night, I used Ubuntu Software to remove VLC. And from some forums I found that I should run:
$ sudo apt-get autoremove vlc
$ sudo apt-get auto clean"
etc (because I wanted to uninstall it completely to reinstall later). But after uninstalling VLC, I am incapable of enabling it again.
This the reason why I can't install VLC again.
yann@yann-Matrimax-PC:~$ sudo apt-get install vlc
[sudo] password for yann:
Reading package lists... Done
Building dependency tree
The following packages have unmet dependencies: vlc : Depends: libgles1-mesa (>= 7.8.1) but it is not going to be installed or libgles1 E: Unable to correct problems, you have held broken packages. yann@yann-Matrimax-PC:~$ ^C
My system is Ubuntu 16.04 LTS, and I run VLC 2.2.5. Could you can help me to solve those troubles? Thanks :)
Maybe you can try removing it completely and installing it directly from the binaries.
sudo apt-get remove vlc
sudo apt-get update
sudo apt-get upgrade
Then download the binaries from http://get.videolan.org/vlc/2.2.8/vlc-2.2.8.tar.xz
Save the file wherever you want to install it. Then, uncompress it:
tar –xzf vlc-2.2.8.tar.xz
You can run the program directly if you want, without installing it by:
./vlc
Or, install it with:
./configure
make install
And finally run it:
./vlc
The file INSTALL inside the tar.xz file contains more information abut the installation.
Good luck!
Also you can try another player, try:
sudo apt-get install totem
Or explain why you "incapable to enable it again" in detail.
LeonidMew
  • 2,802
