I am stuck with this one, have tried apt-get install -f, dpkg --configure -a and they both tell me about the same.
I have no held packages (dpkg -l|grep -i '^h' is empty). Where do I start to look?
# apt-get upgrade
Reading package lists... Done
Building dependency tree
You might want to run 'apt-get -f install' to correct these.
 compiz-plugins : Depends: compiz-core (= 1:0.9.13.1+17.10.20170901-0ubuntu1) but 1:0.9.12.2+16.04.20160823-0ubuntu1 is installed
                  Depends: compiz-plugins-default (= 1:0.9.13.1+17.10.20170901-0ubuntu1) but 1:0.9.12.2+16.04.20160823-0ubuntu1 is installed
 libcompizconfig0 : Depends: compiz-core (= 1:0.9.13.1+17.10.20170901-0ubuntu1) but 1:0.9.12.2+16.04.20160823-0ubuntu1 is installed
 libgail-3-0 : Depends: libgtk-3-0 (= 3.22.25-0ubuntu0.1) but 3.18.9-1ubuntu3.3 is installed
 libmetacity1 : Depends: metacity-common (= 1:3.26.0-1) but 1:3.18.7-0ubuntu0.3 is installed
                Depends: libgtk-3-0 (>= 3.20.0) but 3.18.9-1ubuntu3.3 is installed
 metacity : Depends: metacity-common (= 1:3.26.0-1) but 1:3.18.7-0ubuntu0.3 is installed
            Depends: libgtk-3-0 (>= 3.21.5) but 3.18.9-1ubuntu3.3 is installed
 unity : Depends: libunity-core-6.0-9 (= 7.4.0+16.04.20160906-0ubuntu1) but 7.5.0+17.10.20171010-0ubuntu1 is installed
E: Unmet dependencies. Try using -f.
EDIT: As one answer comments, there are some mixed versions. This is because I tried to do a dist-upgrade to get rid of the error earlier. Apparently it has changed the error, but I believed it to be the same error, and didn't find the dist-upgrade relevant. My bad. I'll look into remove those pkgs then.
EDIT2: I don't think this is an exact duplicate of the two mentioned, at least not on at level I can comprehend.
QUESTION ANSWERED: I think the answers froms user535733 and karel are the ones that helped me. I'm sorry I do no seem to be able to accept the answer officially - could that be because the question is marked as a duplicate? I will try to accept again later.
Anyway: I pegged my installation at 16.04 (apt-get install -t xenial) and went around disabling the 17.10 packages. But then I got lost, gave up and made a clean 17.10 installation. Thanks for your time :-)
NoMann
