Pretty self-explanatory: could someone tell me why I get the error
$ sudo apt-get install gcc-6-base:arm64
dpkg: error processing archive /var/cache/apt/archives/gcc-6-base_6.0.1-0ubuntu1_arm64.deb (--unpack):
 package architecture (arm64) does not match system (amd64)
when
$ sudo apt-get install gcc-6-base:armhf
Selecting previously unselected package gcc-6-base:armhf.
(Reading database ... 219445 files and directories currently installed.)
Preparing to unpack .../gcc-6-base_6.0.1-0ubuntu1_armhf.deb ...
Unpacking gcc-6-base:armhf (6.0.1-0ubuntu1) ...
Setting up gcc-6-base:armhf (6.0.1-0ubuntu1) ...
works just fine on my AMD64 system? How do I fix this?
user541686
  • 4,347
Never mind, I figured it out. You need to run:
sudo dpkg --add-architecture arm64
And you can see the list of existing architectures added via:
sudo dpkg --print-foreign-architectures
Why they think the user must be initially joking about the explicit :arm64 suffix is beyond me. It's not like you don't already have to explicilty add arm64 as an architecture in /etc/sources.list...
user541686
  • 4,347
