I'm running Windows 10 and Xubuntu. I had a windows update few days ago. After that, the GRUB menu disappeared. The solution I used was loading Windows and from command prompt using
bcdedit /set {bootmgr} path \EFI\ubuntu\grubx64.efi
as suggested in Windows 10 upgrade kills grub and boot-repair doesn't help.
This partially solved the problem, now I get to the GRUB and I can load both Windows and Xubuntu BUT after lots of errors before I get to GRUB.
First, when the laptop turns on, I have a few statements:
Failed to open \EFI\Boot\grubx64.efi - Not Found
Failed to load image \EFI\Boot\grubx64.efi: Not Found
start_image() returned Not Found
Failed to open \EFI\BOOT\grubx64.efi - Not Found
Failed to load image \EFI\BOOT\grubx64.efi : Not Found
Then it goes to next screen and it shows me this message:
Default Boot Device Missing or Boot Failed.
Insert Recovery Media and Hit any key
Then Select 'Boot Manager' to choose a new Boot Device or to Boot Recovery
Media
After I click "Ok" (which is the only option here to click), it loads Boot Manager screen:
Boot Option Menu
1. Linpus lite(TOSHIBA MQ01ABF050)
After I click enter because I only have one option here, it repeats error messages I already had on start:
After this, it just loads GNU GRUB with options to choose from Windows and Ubuntu(Xubuntu) etc.
From this point, everything works as usual. I do not get any errors or experience any kind of problems while working on Windows or Xubuntu.
My boot order is set to USB first and Hard Drive second. I tried to change order after I experienced this problem but now I cannot even access my BIOS. This is very unusual behavior, I always could access my BIOS. Now when I press F2 on startup, it doesn't load into BIOS, it asks me for a password. I never set a password for BIOS and I am the first owner of this laptop, nobody else ever used it either. So no mistake there.
I tried just clicking enter and leaving password field blank as I read somewhere but it didn't work.
As I'm a complete newbie to these kind of things, I tried to repair GRUB from Xubuntu but this didn't improve situation (or made it worse).
I'm looking for a solution that includes repairing bcdedit thingy.
Reseting laptop is not a solution right now, I am leaving that as my last option because I have a lot of files to transfer and a lot of projects currently in progress.
Thank you all in advance. And yes, I realize I shouldn't have messed with bcdedit if I'm clueless about it.
UPDATE
As oldfred suggested, I copied all files from /EFI/ubuntu to /EFI/BOOT folder and problem with errors was solved. Or I don't see it anymore, can't tell.
Problem with system asking for BIOS password is still there. I repeat: I never set password; It worked before whole grub mess just fine (I was able to access BIOS); Password isn't blank.
