I did this:
$ uname -r 4.15.0-041500-genericI suspect is because the kernel 4.15 but i wanted to see what you think it is, im struggling with this the whole day
$ git clone https://github.com/jeremyb31/rtl8723de.git Cloning into 'rtl8723de'... remote: Counting objects: 536, done. remote: Total 536 (delta 0), reused 0 (delta 0), pack-reused 536 Receiving objects: 100% (536/536), 2.41 MiB | 356.00 KiB/s, done. Resolving deltas: 100% (195/195), done. Checking connectivity... done.
$ sudo dkms add ./rtl8723de Creating symlink /var/lib/dkms/rtl8723de/5.1.1.8_21285.20171026_COEX20170111-1414/source -> /usr/src/rtl8723de-5.1.1.8_21285.20171026_COEX20170111-1414 DKMS: add completed.
$ sudo dkms install rtl8723de/5.1.1.8_21285.20171026_COEX20170111-1414 Kernel preparation unnecessary for this kernel. Skipping... Building module: cleaning build area.... 'make' all KVER=4.15.0-041500-generic....(bad exit status: 2) ERROR (dkms apport): binary package for rtl8723de: 5.1.1.8_21285.20171026_COEX20170111-1414 not found Error! Bad return status for module build on kernel: 4.15.0-041500-generic (x86_64) Consult /var/lib/dkms/rtl8723de/5.1.1.8_21285.20171026_COEX20170111-1414/build/make.log for more information.
thanks
EDIT:
make.log
$ cat make.log
DKMS make.log for rtl8723de-5.1.1.8_21285.20171026_COEX20170111-1414 for kernel 4.15.0-041500-generic (x86_64)
mar ini 30 14:47:00 PET 2018
make ARCH=x86_64 CROSS_COMPILE= -C /lib/modules/4.15.0-041500-generic/build M=/var/lib/dkms/rtl8723de/5.1.1.8_21285.20171026_COEX20170111-1414/build modules
make[1]: Entering directory '/usr/src/linux-headers-4.15.0-041500-generic'
CC [M] /var/lib/dkms/rtl8723de/5.1.1.8_21285.20171026_COEX20170111-1414/build/core/rtw_cmd.o
In file included from /var/lib/dkms/rtl8723de/5.1.1.8_21285.20171026_COEX20170111-1414/build/include/osdep_service.h:42:0,
from /var/lib/dkms/rtl8723de/5.1.1.8_21285.20171026_COEX20170111-1414/build/include/drv_types.h:32,
from /var/lib/dkms/rtl8723de/5.1.1.8_21285.20171026_COEX20170111-1414/build/core/rtw_cmd.c:22:
/var/lib/dkms/rtl8723de/5.1.1.8_21285.20171026_COEX20170111-1414/build/include/osdep_service_linux.h: In function ‘_init_timer’:
/var/lib/dkms/rtl8723de/5.1.1.8_21285.20171026_COEX20170111-1414/build/include/osdep_service_linux.h:287:8: error: ‘_timer {aka struct timer_list}’ has no member named ‘data’
ptimer->data = (unsigned long)cntx;
/var/lib/dkms/rtl8723de/5.1.1.8_21285.20171026_COEX20170111-1414/build/include/osdep_service_linux.h:288:2: error: implicit declaration of function ‘init_timer’ [-Werror=implicit-function-declaration]
init_timer(ptimer);
cc1: some warnings being treated as errors
scripts/Makefile.build:316: recipe for target '/var/lib/dkms/rtl8723de/5.1.1.8_21285.20171026_COEX20170111-1414/build/core/rtw_cmd.o' failed
make[2]: * [/var/lib/dkms/rtl8723de/5.1.1.8_21285.20171026_COEX20170111-1414/build/core/rtw_cmd.o] Error 1
Makefile:1514: recipe for target 'module/var/lib/dkms/rtl8723de/5.1.1.8_21285.20171026_COEX20170111-1414/build' failed
make[1]: * [module/var/lib/dkms/rtl8723de/5.1.1.8_21285.20171026_COEX20170111-1414/build] Error 2
make[1]: Leaving directory '/usr/src/linux-headers-4.15.0-041500-generic'
Makefile:1884: recipe for target 'modules' failed
make: *** [modules] Error 2
