This answer is a good starting point, but it's not sufficient on UEFI systems.
Here's a step-by-step guide which worked for me.
This answer assumes following partition names:
Device Purpose
/dev/sda2 EFI partition
/dev/sda5 /boot
/dev/sda6 /
A bootable media (live USB etc.) with Ubuntu or some other Linux distribution is required. Make backups before following these steps.
Boot from Ubuntu media and open Terminal (Ctrl+Alt+T). Become root:
sudo su
Mount filesystems of /, /boot and the EFI partition:
cd /mnt
mkdir efi boot os
mount /dev/sda2 efi
mount /dev/sda5 boot
mount /dev/sda6 os
Copy contents of the /boot partition into /boot directory on / partition:
cp -r boot/* os/boot
Prevent Ubuntu from mounting /boot automatically. Also take note of root partition's UUID. Open /etc/fstab in your preferred editor:
gedit os/etc/fstab
Here's what mine looked like (save for comments):
UUID=df89aab6-941d-4ffa-9681-e16fc94641d3 / ext4 errors=remount-ro 0 1
UUID=f7c32b17-a2f1-4eb3-a8e7-414b6a228a72 /boot ext4 defaults 0 2
UUID=2252-1B80 /boot/efi vfat umask=0077 0 1
UUID=a80bb662-d531-408b-bc23-b47f28c44ec4 /home ext4 defaults 0 2
/swapfile none swap sw 0 0
I have commented out the second line which mounts /boot. I have also copied UUID of / partition, we'll need that in a moment.
Update GRUB's configuration on the EFI partition. This step is crucial on UEFI systems.
cd /mnt/efi/EFI/ubuntu
cp grub.cfg grub.cfg.bak
gedit grub.cfg
My grub.cfg looked like this:
search.fs_uuid f7c32b17-a2f1-4eb3-a8e7-414b6a228a72 root hd1,gpt5
set prefix=($root)'/grub'
configfile $prefix/grub.cfg
I had to update: 1. the UUID, 2. the partition number and 3. the prefix. Modified file looks like this:
search.fs_uuid df89aab6-941d-4ffa-9681-e16fc94641d3 root hd1,gpt6
set prefix=($root)'/boot/grub'
Note that it's the same UUID I got from /etc/fstab and I had to prepent /boot to the prefix.
Reboot into Ubuntu on your hard disk. It should boot just fine. Make sure /boot isn't mounted - grep /boot /etc/mtab should output nothing. Format the old /boot partition (don't confuse it with current /boot, which is a regular directory) and refresh GRUB config:
sudo mkfs.ext4 /dev/sda5
sudo update-grub
Reboot once more, confirm that the OS is up and do whatever you want with your ex-boot partition.
