Brand new installed system 16.04LTS, only installed Xenial packages.
sudo apt install libgnutls-dev
results in
Reading package lists... Done
Building dependency tree
 libgnutls-dev : Depends: libgnutls30 (= 3.4.10-4ubuntu1) but 3.4.10-4ubuntu1.4 is to be installed
                 Depends: libgnutls-openssl27 (= 3.4.10-4ubuntu1) but 3.4.10-4ubuntu1.4 is to be installed
                 Depends: libgnutlsxx28 (= 3.4.10-4ubuntu1) but it is not going to be installed
                 Depends: nettle-dev but it is not going to be installed
                 Depends: libtasn1-6-dev but it is not going to be installed
                 Depends: libp11-kit-dev but it is not going to be installed
                 Depends: libidn11-dev (>= 1.31) but it is not going to be installed
The error message (xxx is there but xxxx+version is to be installed) makes no sense whatsoever. There is nothing to be installed other than the packages listed.
sudo apt install -f results in nada:
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
apt-cache policy libgnutls-dev
gives
libgnutls-dev:
  Installed: (none)
  Candidate: 3.4.10-4ubuntu1
  Version table:
     3.4.10-4ubuntu1 500
        500 http://au.archive.ubuntu.com/ubuntu xenial/main amd64 Packages
Suggestions anyone?
Balthasar
  • 173
Current version of libgnutls-dev on xenial is 3.4.10-4ubuntu1.4.
It seems that you disabled xenial-updates repository.
  • On desktop open Software & Updates (software-properties-gtk), go to Updates tab and check xenial-security and xenial-updates.
  • On server you should have the following line in /etc/apt/sources.list:
    deb http://archive.ubuntu.com/ubuntu xenial-updates main restricted universe multiverse
And try to install it again.
N0rbert
  • 103,263
