I am trying to install 16.4 on an Acer aspire e11 but it will not boot after install. It runs OK from the live usb drive any suggestions please.
On my Acer Aspire there vas a line missing in the fstab file (/etc/fstab), the EFI system partition! run:
$ sudo blkid
/dev/loop0: TYPE="squashfs"
/dev/loop1: TYPE="squashfs"
/dev/loop2: TYPE="squashfs"
/dev/loop3: TYPE="squashfs"
/dev/loop4: TYPE="squashfs"
/dev/loop5: TYPE="squashfs"
/dev/loop6: TYPE="squashfs"
/dev/loop7: TYPE="squashfs"
/dev/sda1: LABEL="ESP" UUID="30AB-667B" TYPE="vfat" PARTLABEL="EFI system partition" PARTUUID="623e7385-ee5d-49b8-bc18-dbde551f5067"
/dev/sda3: LABEL="Acer" UUID="8A1EAD321EAD1869" TYPE="ntfs" PARTLABEL="Basic data partition" PARTUUID="8ae7090d-3565-438e-9146-073ec0670de3"
/dev/sda4: LABEL="Recovery" UUID="2CD2AF55D2AF2256" TYPE="ntfs" PARTLABEL="Basic data partition" PARTUUID="e337e795-6016-4fdc-a552-3d3cf469b6c9"
/dev/sda5: UUID="b81dd225-11b1-4783-81ff-1572f8058c23" TYPE="swap" PARTLABEL="Swap area" PARTUUID="71233eb1-916f-4bc1-bcfa-dd62f662c81a"
/dev/sda6: LABEL="MintXfce" UUID="05130fba-7126-4d1c-8bfa-bde9f2a79ea9" TYPE="ext4" PARTLABEL="Linux Mint" PARTUUID="e38142cd-8120-4764-bd17-8a8fae6a2aa3"
/dev/sda7: LABEL="Voyager" UUID="3068f167-88f1-44bb-8b5d-628681dd9536" TYPE="ext4" PARTLABEL="Vouager" PARTUUID="73b60fe3-bc04-40a4-aeee-ff4cdb3cf5db"
/dev/sda8: LABEL="Ubuntu" UUID="53942c96-b474-4589-9d0f-239b39dcd39a" TYPE="ext4" PARTLABEL="Xubuntu" PARTUUID="ec9949ad-ac5d-4d97-906b-d3963010e6f9"
/dev/sda9: LABEL="Security" UUID="62e607e2-6539-416d-b323-46ca4f5543e2" TYPE="ext4" PARTLABEL="Kali" PARTUUID="d4004d4f-0896-4184-ae85-cc2d1746b0ba"
/dev/sda10: LABEL="Hjem" UUID="7dc71844-bb39-4e9b-83c9-472f7d94b16d" TYPE="ext4" PARTLABEL="Data" PARTUUID="f4be90c7-c698-432c-8b08-175fd5c02c69"
/dev/sda11: LABEL="wmlive" UUID="009713f7-0c5a-485f-9a9b-ab59037765b9" TYPE="ext4" PARTLABEL="WMlive" PARTUUID="52e8749e-eb56-4132-abe9-77f1aa82c528"
/dev/sda2: PARTLABEL="Microsoft reserved partition" PARTUUID="e09f4516-a38d-4564-ac2e-1fdfdaef6d83"
The line we are looking for is:
Then you have to enter that information (with your own systems UUID's) in the fstab file:
# /etc/fstab: static file system information
# Use 'blkid' to print the universally unique identifier for a
# device; this may be used with UUID= as a more robust way to name devices
# that works even if disks are added and removed. See fstab(5).
# <file system> <mount point>   <type>  <options>       <dump>  <pass>
# / was on /dev/sda8 during installation
UUID=53942c96-b474-4589-9d0f-239b39dcd39a /             ext4    errors=remount-ro 0       1
# /boot/efi was Missing on /dev/sda1 during installation
UUID=30AB-667B  /boot/efi       vfat    umask=0077      0       1
# swap was on /dev/sda5 during installation
UUID=b81dd225-11b1-4783-81ff-1572f8058c23 none          swap    sw              0       0
# Hjem was not loaded at installation /dev/sda10: LABEL="Hjem" UUID="7dc71844-bb39-4e9b-83c9-472f7d94b16d" TYPE="ext4"
UUID=7dc71844-bb39-4e9b-83c9-472f7d94b16d /mnt/hjem ext4    relatime    0   2
It is the line after the one that start with # /boot/efi
Forget the last 2 lines it is my setup- save the file (you need to edit with sudo rights - else you can't save your changes!
Now reboot and it should start propper!
muru
  • 207,228
Ken Mollerup
  • 1,315
Bit late in the game, but BIOS not seeing Ubuntu installed on Acer Aspire ES1-132. Can boot via grub cli any use?
(worked for me on Acer Aspire ES1)
In case you have issue when installing on UEFI BIOS (not sure if this issue is adressed only to Acer Laptops) there is a topic here that helped me solve this issue.
I will copy the commands in case it disappears, but all credit goes to Pueseso from Acer Community forum.
  • Boot Ubuntu Live USB
  • open terminal
sudo -s
ubiquity -b
sudo mount /dev/sda2 /mnt #sda2 is the root partition
sudo mkdir /mnt/boot/efi
sudo mount /dev/sda1 /mnt/boot/efi #sda1 is the efi partition
for i in /dev /dev/pts /proc /sys; do sudo mount -B $i /mnt$i; done
modprobe efivars # make sure this is loaded
  • notice the bootx64 file
efibootmgr --verbose
  • We will reinstall grub-install for a 64bit version
apt-get install --reinstall grub-efi-amd64
grub-install -no-nvram --root-directory=/mnt
chroot /mnt
update-grub
cd /boot/efi/EFI
cp -R ubuntu BOOT
cd BOOT
cp grubx64.efi bootx64.efi
  • You are finished, reboot the system.
Raffa
  • 34,963
