I recently switched my surface pro 3 to Ubuntu 17.10. I'm new to Linux, but need to have it for a class I'm taking and can't afford to buy a mac. The surface was given to me by my former employer, so I need to do my best to make it work if possible. Here's the issue. The network driver is constantly crashing on wifi, even when I'm ten feet from the router. I've done as much research as possible on this and I can't seem to find any one answer that gets me close.
At first, I tried restarting the network manager using the terminal. Nothing. It just said network disconnected. Before anyone asks, there is no wifi kill-switch on the surface and when checking for blocks through the terminal, there are no hard or soft blocks detected. It is just disconnected. I tried switching the wifi button in the settings off and back on again. Nothing.
From what I gathered, basically the way the network manager operates, it's constantly trying to find a better connection and can get overloaded and crash. So I tried manually setting the BSSID. Worked for a while, but only for a few hours before the problem began repeating itself again.
Onwards. I tried to get rid of the built-in network manager and replaced it with wicd. It seemed to work for a while, except that I noticed that I no longer had access to my settings. Any settings. It was just gone. I couldn't add bluetooth devices because I'm assuming the built-in network manager was in charge of that, but I couldn't even adjust display settings. There was just no settings. Fine, I'm ok with that as long as I have wifi. problem is after a few hours, it started dropping again. Then by the end of the night, it would barely even connect for more than ten minutes.
Back at square one. I reinstalled nmcli because I figured if I'm not going to have wifi, I might as well have my settings back. But I noticed something. Where once after every crash, lshw -C network would read "*-network disconnected" it now does not show disconnected. But still cannot find any networks. Here's what I think the solution is, but have no developing or IT experience and am hoping someone can help. I think there isn't a network manager out there yet built to fully integrate with the surface on linux simply because the surface is a Microsoft product and this isn't a common use of it, so the driver hasn't come about. But maybe someone can point me in the right direction.
nmcli device - wifi: wlp1s0 lo - loopback: unmanaged
product: 88W8879 [AVASTAR] 802.11ac Wireless vendor: Marvell Technology Group physical id: 0
so on and so forth. If there is any other information I should provide, let me know, but tell me how because I've exhausted my knowledge. I really appreciate any help, advice or direction someone can give me. Thanks people.
