I am getting the below dependency errors while installing wireshark on my machine
 wireshark : Depends: wireshark-qt but it is not going to be installed or
                      wireshark-gtk but it is not going to be installed
Why it is not installing these wireshark dependencies and how can I fix it?
Below is my system configuration
Linux shadows 4.8.0-46-generic #49~16.04.1-Ubuntu SMP Fri Mar 31 14:51:03 UTC 2017 x86_64 x86_64 x86_64 GNU/Linux
Edit 1
$ sudo apt-cache policy wireshark wireshark-qt wireshark-gtk
wireshark:
  Installed: (none)
  Candidate: 2.4.3-1~zesty1
  Version table:
     2.4.3-1~zesty1 500
        500 http://ppa.launchpad.net/wireshark-dev/stable/ubuntu zesty/main amd64 Packages
     2.2.6+g32dac6a-2ubuntu0.16.04 500
        500 http://archive.ubuntu.com/ubuntu xenial-updates/universe amd64 Packages
        500 http://security.ubuntu.com/ubuntu xenial-security/universe amd64 Packages
     2.0.2+ga16e22e-1 500
        500 http://archive.ubuntu.com/ubuntu xenial/universe amd64 Packages
wireshark-qt:
  Installed: (none)
  Version table:
     2.4.3-1~zesty1 500
wireshark-gtk:
  Installed: (none)
  Version table:
     2.4.3-1~zesty1 500
Edit2
$ cat /etc/os-release
NAME="Ubuntu"
VERSION="17.04 (Zesty Zapus)"
ID=ubuntu
ID_LIKE=debian
PRETTY_NAME="Ubuntu 17.04"
VERSION_ID="17.04"
HOME_URL="https://www.ubuntu.com/"
SUPPORT_URL="https://help.ubuntu.com/"
BUG_REPORT_URL="https://bugs.launchpad.net/ubuntu/"
PRIVACY_POLICY_URL="https://www.ubuntu.com/legal/terms-and-policies/privacy-policy"
VERSION_CODENAME=zesty
UBUNTU_CODENAME=zesty
Zanna
  • 72,312
Prateek Joshi
  • 320
The solution is to remove Wireshark PPA and install Wireshark from Ubuntu universe repository:
sudo apt-get install ppa-purge
sudo ppa-purge ppa:wireshark-dev/stable
sudo apt-get install wireshark
N0rbert
  • 103,263
