-> i installed ubuntu alongside windows10 -> both are installed in UEFI mode -> but it automatically start windows10 -> i have separate partition Named as EFI which contain EFI\Boot\ EFI\Microsoft\Boot EFI\ubuntu(some Files)
EFI\ubuntu(Files list)
when i want to start UBUNTU at that time i have to press NOVO(Special Button On Lenovo Laptop for Go in Bios Or Select Boot option) button and select ubuntu
but it is not convenient way because novo button is pressed by only tiny pin
so anyone have any solution which is show me GRUB or bootselection at that time of starting my laptop
thanks in advance
Maybe you can try installing Boot Repair.
This will help you to recover the properly boot systems from other operative systems.
First, install the repositories
sudo add-apt-repository ppa:yannubuntu/boot-repair
Then, update them
sudo apt-get update
Later, install the program
sudo apt-get install -y boot-repair && boot-repair
Then, a screen like this will appear:
Use the recommended repair, or take a look the the Community help page of the program (linked above)
As Commented above by ravery i just change boot order in UEFI setting and it first show me grub2.0 with windows and ubuntu option selection
thank you all of you to quick support
