If I got well the idea of dropout, it allows improving the sparsity of the information that comes from one layer to another by setting some weights to zero.
On the other hand, pooling, let's say max-pooling, takes the maximum value in a neighborhood, reducing as well to zero, the influence of values apart from this maximum.
Without considering the shape transformation due to the pooling layer, can we say that pooling is a kind of a dropout step?
Would the addition of a dropout (or DropConnect) layer, after a pooling layer, make sense in a CNN? And does it help the training process and generalization property?
nbro
  • 42,615
  • 119
  • 217
nsaura
  • 258
Dropout and Max-pooling are performed for different reasons.
Dropout is a regularization technique, which affects only the training process (during evaluation, it is not active). The goal of dropout is reduce unnecessary feature dependencies in the network, allowing it to be simpler and improves its generalization abilities (reduces overfitting). In simple terms, it helps the model to learn that some features are an "OR" and not an "AND" requirements.
Max-pooling is not a regularization technique and it is part of the model's architecture, so it is also used during evaluation. The goal of max-pooling is to down-sample an input representation. As a result the model becomes less sensitive to some translations (improving translation invariance).
As for your last question, yes. dropout can be used after a pooling layer.
Mark.F
  • 446
  • 16
I think we would consider regularization and downsampling better in this way:
  1. dropout
it puts some input value (neuron) for the next layer as 0, which makes the current layer a sparse one. So it reduces the dependence of each feature in this layer.
  1. pooling layer
the downsampling directly remove some input, and that makes the layer "smaller" rather than "sparser". The difference can be subtle but clear enough.
That's the root reason why the former also affect the evaluation/test process but the later does not.
Bs He
  • 121
