With the advancement of deep learning and a few others automated features learning techniques, manual feature engineering started becoming obsolete.
Any suggestion on when to use manual feature engineering, feature learning or a combination of the two?
nbro
  • 42,615
  • 119
  • 217
Ruchit Dalwadi
  • 335
That is wrong.
Deep learning is awesome for natural signals like images, audio or large amounts of unstructured text (e.g. arbitrary crawled websites)
There are some basic steps that make almost always sense. For example, for image recognition, it is the normalization from pixel color features in the range $\{0, 1, \dots, 255 \}$ to features in $[0, 1]$.
And then there are a lot of use cases where you have structured, CSV-like data. For those, every single case I had so far was improved by feature engineering. Most of the time you actually don't have a choice here as well: how would you feed in a date time object into a neural network?
Now, where does feature engineering make sense in image recognition?
  • Resource limitations: neural networks often take a lot of resources. For example, viola-jones face detection is very resource friendly in contrast. But there are developments like the mobile net to relax that issue.
  • Prior knowledge: for more special image data like CT scans you might observe super simple operations that almost give you the target. This might make it simpler to interpret the results at the end and, again, it helps to keep resource usage low.
One other field where I suspect that manual feature engineering could help is adversarial attacks. But for this I'm not 100% sure.
nbro
  • 42,615
  • 119
  • 217
Martin Thoma
  • 1,055
  • 17
