In a CNN, does each new filter have different weights for each input channel, or are the same weights of each filter used across input channels?
This question helps me a lot.
Let, I have RGB input image. (3 channels) Then each filter has n×n weights for one channel. It means, actually the filter has totally 3×n×n weights.
For channel R, it has own n×n filter.
For channel G, it has own n×n filter.
For channel B, it has own n×n filter.
After inner product, add them all to make one feature map. Am I right?
And then, my question starts here. For some purpose, I will only use greyscale images as input. So the input images always have the same values for each RGB channel.
Then, can I reduce the number of weights in the filters? Because in this case, using three different n×n filters and adding them is same with using one n×n filter that is the summation of three filters.
Does this logic hold on a trained network? I have a trained network for RGB image input, but it is too heavy to run in real time. But I only use the greyscale images as input, so it seems I can make the network less heavy (theoretically, almost 1/3 of original).
I'm quite new in this field, so detailed explanations will be really appreciated. Thank you.
Jun
  • 89
  • So you have a pre trained CNN on rgb images...and now you want to use it on greyscale images? –  Sep 13 '18 at 10:19
  • Yes, right. And it's impossible to retrain because I don't have training set... – Jun Sep 13 '18 at 10:30
  • Sum up : No you don't reduce your number of weights by 3, you reduce your first layer number of weights by 3 only ! – Jérémy Blain Sep 13 '18 at 10:30
  • @Jun Then maybe you should stay with the former CNN model. Or maybe try to reduce the number of weights, but it's not obvious that the network works better.... – Jérémy Blain Sep 13 '18 at 10:31
  • @JérémyBlain Probably will not work. –  Sep 13 '18 at 10:32
  • Unless you have some very unusual images (e.g mostly one colour) then this is a very bad way to improve inference performance as anything you do will badly affect accuracy. If you don't have access to training data to retrain a network you should look into other routes (e.g TensorRT or better hardware) to improve inference performance. – Mike Vella Sep 13 '18 at 10:47
yes, you are right.
If you have transformed the image into greyscale then you no longer need 3 filters. You should retrain your model on greyscale images. In a greyscale image the value of each pixel is a single sample representing only an amount of light (the light intensity).
The network will run faster if that is the only architectural change you make, but keep in mind that by converting the image to greyscale you will lose information and probably some of the predictive power of your network.
Mike Vella
  • 119
Yes you are right. Now I will try to perform a transformation to preserve accuracy, cannot say about efficiency of the method.
Note: I have not worked on such type of problem, but knowing the maths behind CNN I will try to solve the problem theoretically.
First you have to know the RGB to greyscale conversion formulae which have bben used. Here are some common schemes.
So let us say each pixel had values $r, g, b$ and you converted it to $x_1*r + x_2*g +x_3*b$. So initially for simplicity let us say the we are talking about the corner pixel and convolution scheme $valid$, so the corner pixel with $RGB$ channels get multiplied with values $w_r, w_g, w_b$ during convolution and gets summed up.
But now you only have one pixel which is $x_1*r + x_2*g +x_3*b$. Now let us multiply this by $\frac {w_r}{x_1} + \frac {w_g}{x_2} + \frac {w_b}{x_3}$. This will result in: $(w_r*r + w_g*g +w_b*b) + (\frac {w_r*(x_2*g + x_3*b)}{x_1} +\frac {w_g*(x_1*r + x_3*b)}{x_2} + \frac {w_b*(x_2*g + x_1*r)}{x_3})$.
Now we have to try to remove the 2nd term of the equation. The paramters $w_r, w_g, w_b, x_1, x_2, x_3$ are predetermined already. So taking a single term $r$ from the second term of the equation gives $r*(\frac {w_g*x_1}{x_2} + \frac {w_b*x_1}{x_3})$. The second term has pre-determined value, and for the $r$ I think somehow using modern image analysis techniques you can find some approximate value of possible $r$. Do this for $g$ and $b$ as well and subtract it from the aforementioned equation and you will finally get $(w_r*r + w_g*g +w_b*b)$ which was the term obtained by convolution of filters with $RGB$ images.
I have done all this hypothetically, such image analysis techniques might not exist, but it is still worth a try. Probably better methods to reduce the second term exists in mathematical literature. I will leave it upto mathematicians to point in the right direction.
