50
I've heard the terms strong-AI and weak-AI used. Are these well defined terms or subjective ones? How are they generally defined?
nbro
  • 42,615
  • 119
  • 217
WilliamKF
  • 2,533
  • 26
  • 31
The terms strong and weak don't actually refer to processing, or optimization power, or any interpretation leading to "strong AI" being stronger than "weak AI". It holds conveniently in practice, but the terms come from elsewhere. In 1980, John Searle coined the following statements:
  • AI hypothesis, strong form: an AI system can think and have a mind (in the philosophical definition of the term);
  • AI hypothesis, weak form: an AI system can only act like it thinks and has a mind.
So strong AI is a shortcut for an AI systems that verifies the strong AI hypothesis. Similarly, for the weak form. The terms have then evolved: strong AI refers to AI that performs as well as humans (who have minds), weak AI refers to AI that doesn't.
The problem with these definitions is that they're fuzzy. For example, AlphaGo is an example of weak AI, but is "strong" by Go-playing standards. A hypothetical AI replicating a human baby would be a strong AI, while being "weak" at most tasks.
Other terms exist: Artificial General Intelligence (AGI), which has cross-domain capability (like humans), can learn from a wide range of experiences (like humans), among other features. Artificial Narrow Intelligence refers to systems bound to a certain range of tasks (where they may nevertheless have superhuman ability), lacking capacity to significantly improve themselves.
Beyond AGI, we find Artificial Superintelligence (ASI), based on the idea that a system with the capabilities of an AGI, without the physical limitations of humans would learn and improve far beyond human level.
jrmyp
  • 556
In contrast to the philosophical definitions, which rely on terms like "mind" and "think," there are also definitions that hinge on observables.
That is, a Strong AI is an AI that understands itself well enough to self-improve. Even if it is philosophically not equivalent to a human, or unable to perform all cognitive tasks that a human can, this AI can still generate a tremendous amount of optimization power / good decision-making, and its creation would be of historic importance (to put it lightly).
A Weak AI, in contrast, is an AI with no or limited ability to self-modify. A chessbot that runs on your laptop might have superhuman ability to play chess, but it can only play chess, and while it might tune its weights or its architecture and slowly improve, it cannot modify itself in a deep enough way to generalize to other tasks.
Another way to think about this is that a Strong AI is an AI researcher in its own right, and a Weak AI is what AI researchers produce.
Matthew Gray
  • 4,272
  • 19
  • 28
Strong and weak AI are the older terms for AGI (artificial general intelligence) and narrow AI. At least that's how I have seen it used and wikipedia seems to agree.
I personally haven't seen Searle's definition of "weak and strong AI" in use much, but maybe the shift to the newer terms came about in part because Searle successfully confused the issue.
BlindKungFuMaster
  • 4,265
  • 13
  • 23
