48
As far as I understand, Q-learning and policy gradients (PG) are the two major approaches used to solve RL problems. While Q-learning aims to predict the reward of a certain action taken in a certain state, policy gradients directly predict the action itself.
However, both approaches appear identical to me, i.e. predicting the maximum reward for an action (Q-learning) is equivalent to predicting the probability of taking the action directly (PG). Is the difference in the way the loss is back-propagated?
nbro
  • 42,615
  • 119
  • 217
Tejas Ramdas
  • 605
However, both approaches appear identical to me i.e. predicting the maximum reward for an action (Q-learning) is equivalent to predicting the probability of taking the action directly (PG).
Both methods are theoretically driven by the Markov Decision Process construct, and as a result use similar notation and concepts. In addition, in simple solvable environments you should expect both methods to result in the same - or at least equivalent - optimal policies.
However, they are actually different internally. The most fundamental differences between the approaches is in how they approach action selection, both whilst learning, and as the output (the learned policy). In Q-learning, the goal is to learn a single deterministic action from a discrete set of actions by finding the maximum value. With policy gradients, and other direct policy searches, the goal is to learn a map from state to action, which can be stochastic, and works in continuous action spaces.
As a result, policy gradient methods can solve problems that value-based methods cannot:
  • Large and continuous action space. However, with value-based methods, this can still be approximated with discretisation - and this is not a bad choice, since the mapping function in policy gradient has to be some kind of approximator in practice.
  • Stochastic policies. A value-based method cannot solve an environment where the optimal policy is stochastic requiring specific probabilities, such as Scissor/Paper/Stone. That is because there are no trainable parameters in Q-learning that control probabilities of action, the problem formulation in TD learning assumes that a deterministic agent can be optimal.
However, value-based methods like Q-learning have some advantages too:
  • Simplicity. You can implement Q functions as simple discrete tables, and this gives some guarantees of convergence. There are no tabular versions of policy gradient, because you need a mapping function $p(a \mid s, \theta)$ which also must have a smooth gradient with respect to $\theta$.
  • Speed. TD learning methods that bootstrap are often much faster to learn a policy than methods which must purely sample from the environment in order to evaluate progress.
There are other reasons why you might care to use one or other approach:
  • You may want to know the predicted return whilst the process is running, to help other planning processes associated with the agent.
  • The state representation of the problem lends itself more easily to either a value function or a policy function. A value function may turn out to have very simple relationship to the state and the policy function very complex and hard to learn, or vice-versa.
Some state-of-the-art RL solvers actually use both approaches together, such as Actor-Critic. This combines strengths of value and policy gradient methods.
nbro
  • 42,615
  • 119
  • 217
Neil Slater
  • 33,739
  • 47
  • 66
16
This Tutorial by OpenAI offers a great comparison of different RL methods.
I'll try to summarize the differences between Q-Learning and Policy Gradient methods:
  1. Objective Function
    1. In Q-Learning we learn a Q-function that satisfies the Bellman (Optimality) Equation. This is most often achieved by minimizing the Mean Squared Bellman Error (MSBE) as the loss function. The Q-function is then used to obtain a policy (e.g. by greedily selecting the action with maximum value).
    2. Policy Gradient methods directly try to maximize the expected return by taking small steps in the direction of the policy gradient. The policy gradient is the derivative of the expected return w.r.t. the policy parameters.
  2. On- vs. Off-Policy
    1. The Policy Gradient is derived as an expectation over trajectories ($s_1,a_1,r_1,s_2,a_2,...,r_n$), which is estimated by a sample mean. To get an unbiased estimate of the gradient, the trajectories have to be sampled from the current policy. Thus, policy gradient methods are on-policy methods.
    2. Q-Learning only makes sure to satisfy the Bellman-Equation. This equation has to hold true for all transitions. Therefore, Q-learning can also use experiences collected from previous policies and is off-policy.
  3. Stability and Sample Efficiency
    1. Directly optimizing the return and thus the actual performance on a given task, Policy Gradient methods tend to more stably converge to a good behavior. Indeed being on-policy, makes them very sample inefficient. Q-learning find a function that is guaranteed to satisfy the Bellman-Equation, but this does not guarantee to result in near-optimal behavior. Several tricks are used to improve convergence and in this case, Q-learning is more sample efficient.
Rustam
  • 471
