Backgroud
sbx is a jax implementation of stable-baselines3. As claimed here, it can accelate RL training by jit compared to sb3+pytorch.
Question
I tested sbx ppo and sb3 ppo on gym env Hopper-v5. The results shows that neither sbx on cpu or sbx on cuda is significantly faster than sb3 on cpu. Only 1.06x speedup is achieved according to the fps(frame per second) graph.
Episodic return mean learning curve(green: sbx on cpu and cuda, red: sb3 on cpu):
fps(frame per second) graph:
My question are:
- Is the result expected? if it is what is benefit to use sbx ppo? if not where did I implement wrong?
- Is the performance improvements claimed here still true in 2025?
Additional context
Companion github issues.
The hyparameters of all runs are kept consistent as below:
batch_size:64
device:"cuda"
env_id:"hopper"
learning_rate:0.0001
n_envs:16
n_epochs:10
n_steps:128
seed:0
total_timesteps:1,000,000
System hardware:
| item | value |
| CPU count | 8 |
| Logical CPU count | 16 |
| GPU count | 1 |
| GPU type | NVIDIA GeForce RTX 3080 Ti |
Here is the wandb report: https://wandb.ai/zhixin/jaxrl/reports/performance-compare-sbx-vs-sb3-ppo--VmlldzoxMjU0ODY2NQ
Code can be found here
Run script:
# sbx gym cpu
python -O sb3_learn.py --sbx --seed 0 --n_envs 16 --n_steps 128 --learning_rate 0.0001 --batch-size 64 --total_timesteps 1000000
sbx gym cuda
python -O sb3_learn.py --sbx --device cuda --seed 0 --n_envs 16 --n_steps 128 --learning_rate 0.0001 --batch-size 64 --total_timesteps 1000000
sb3 gym cpu
python -O sb3_learn.py --seed 0 --n_envs 16 --n_steps 128 --learning_rate 0.0001 --batch-size 64 --total_timesteps 1000000
