DL is algorithm-like in terms of their outcomes but often emerge through brute-force exploration of solution spaces rather than human-like conceptual insight. The line between "discovering a new algorithm" and "optimizing a known process" can be blurry, but examples like AlphaTensor show clear cases of algorithmic innovation.
In 2022, DeepMind introduced AlphaTensor, a neural network that used a single-player game analogy to invent thousands of matrix multiplication algorithms, including some previously discovered by humans and some that were not... Finding low-rank decompositions of such tensors (and beyond) is NP-hard; optimal multiplication even for 3x3 matrices remains unknown, even in commutative field. On 4x4 matrices, AlphaTensor unexpectedly discovered a solution with 47 multiplication steps, an improvement over the 49 required with Strassen’s algorithm of 1969, albeit restricted to mod 2 arithmetic. Similarly, AlphaTensor solved 5x5 matrices with 96 rather than Strassen's 98 steps. Based on the surprising discovery that such improvements exist, other researchers were quickly able to find a similar independent 4x4 algorithm, and separately tweaked Deepmind's 96-step 5x5 algorithm down to 95 steps in mod 2 arithmetic and to 97 in normal arithmetic. Some algorithms were completely new: for example, (4, 5, 5) was improved to 76 steps from a baseline of 80 in both normal and mod 2 arithmetic.
Fawzi, Alhussein, Matej Balog, Aja Huang, Thomas Hubert, Bernardino Romera-Paredes, Mohammadamin Barekatain, Alexander Novikov, et al. “Discovering Faster Matrix Multiplication Algorithms with Reinforcement Learning.” Nature 610, no. 7930 (October 2022): 47–53.
However, this remains niche compared to the broader landscape of algorithm design, which still relies heavily on human creativity currently. In practice, a network trained to solve a problem (like XOR) is often simply learning a parameterization heuristically that approximates the function that you might also compute with a known algorithm or by hand in theory. Deep learning models whether general-purpose GPTs or specialized reasoning models, are all ultimately function approximators based on known principles.
