as the title suggests, I'm trying to convert a notebook in keras 3, but idk why it's not working properly.
This is the original notebook (tell me if it's better to put here the code), I'm trying to do the same task but with car fronts; at the end you can find my code.
I managed to make it work with keras 2, now converting it to keras 3, but in kaggle seems really slow: I tried disabling GPU and it gets worse, so I know that it's using the GPU but CPU is always 100% and I can't figure why. My updated code is 5 times slower then the original one, while using old keras it has the same speed of the original code.
How can I do better? There is something that I'm missing? I followed keras official guide to convert keras 2 to keras 3, I'm thinking about learning pytorch but my model should run on constraint hardware, so I want to use tf lite to convert the model automatically (I'll use tf as backend for keras 3)
Furthermore, the model receives 5 tensors without using data = data[0], because data[0] is the list of batches (anchors, positive and negative) while data1 and data[2] are empty. This problem is in train_step and test_step, how can I manage that problem in a cleaner way?
My updated code for keras 3 (I prefer to copy this so it doesn't changes, I'll make a static notebook with a run if you prefer to see the correctness of code but the 20 s/it or more as speed):
import os
import zipfile
import random import math import pandas as pd
import cv2 import numpy as np import matplotlib.pyplot as plt from scipy import ndimage from tqdm import tqdm
from sklearn.model_selection import train_test_split
import tensorflow as tf import keras from keras.models import Model from keras.layers import Layer, Flatten, Dense,
Dropout, BatchNormalization, Input from keras.metrics import Mean, CosineSimilarity from keras.optimizers import Adam from keras.utils import plot_model from tensorflow.keras.preprocessing.image import ImageDataGenerator from keras.applications.efficientnet import EfficientNetB7, preprocess_input
os.environ["KERAS_BACKEND"] = "tensorflow"
#!conda install -y gdown if not(os.path.isdir('/kaggle/working/confirmed_fronts')): !gdown https://drive.google.com/uc?id=1e1ajCFntWRVeCluTvSJ6gV-2ew6F0ys5
!unzip -qq Confirmed_fronts.zip
!rm -rf /kaggle/working/Confirmed_fronts.zip
%cd /kaggle/working/confirmed_fronts
!find . -type f | awk -F '/' '{print $4}' | awk -F '\\$\\<span class="math-container">$' 'BEGIN{print "Maker name,Model name,Registration year,Color,Genmodel ID,Adv ID,Image index"}1 {print $1 "," $2 "," $3 "," $4 "," $5 "," $6 "," $7}' > car_fronts.csv
df2 = pd.read_csv('car_fronts.csv', delimiter=',')
df2 = df2.dropna(how='all',axis=0)
df2['Registration year'] = df2['Registration year'].astype(int) df2['Adv ID'] = df2['Adv ID'].astype(int)
df2
df2vc = df2[['Maker name', 'Model name', 'Registration year', 'Color']].value_counts()
df2vc
df2vcFiltered = df2vc[df2vc >= 5] df2vcFiltered
def triplets_generator(max_triplets=10, sample_lim=len(df2vcFiltered), val_set_perc=0.2, test_set_perc=0.1, print_paths=False, high_filter=False):
images_tr  = []
images_val = []
images_te  = []
for row in range(sample_lim):
    images_row = []
    index = df2vcFiltered.index[row]
    for i in range(max_triplets):
        random_choice1 = df2[(df2['Maker name'] == index[0]) &amp; (df2['Model name'] == index[1]) &amp; (df2['Registration year'] == index[2]) &amp; (df2['Color'] == index[3])].sample()
        path1 = str(random_choice1['Maker name'].iloc[0]) + '/' + str(random_choice1['Registration year'].iloc[0].astype(int)) + '/' + str(random_choice1['Maker name'].iloc[0]) + '<span class="math-container">$$' + str(random_choice1['Model name'].iloc[0]) + '$$</span>' +  str(random_choice1['Registration year'].iloc[0].astype(int)) + '<span class="math-container">$$' + str(random_choice1['Color'].iloc[0]) + '$$</span>' + str(random_choice1['Genmodel ID'].iloc[0]) + '<span class="math-container">$$' + str(random_choice1['Adv ID'].iloc[0].astype(int)) + '$$</span>' + str(random_choice1['Image index'].iloc[0])
        while True:                  #TODO better way to write it? Do while not implemented
            random_choice2 = df2[(df2['Maker name'] == index[0]) &amp; (df2['Model name'] == index[1]) &amp; (df2['Registration year'] == index[2]) &amp; (df2['Color'] == index[3])].sample()
            if random_choice1.index != random_choice2.index:
                break
        path2 = str(random_choice2['Maker name'].iloc[0]) + '/' + str(random_choice2['Registration year'].iloc[0].astype(int)) + '/' + str(random_choice2['Maker name'].iloc[0]) + '<span class="math-container">$$' + str(random_choice2['Model name'].iloc[0]) + '$$</span>' + str(random_choice2['Registration year'].iloc[0].astype(int)) + '<span class="math-container">$$' + str(random_choice2['Color'].iloc[0]) + '$$</span>' + str(random_choice2['Genmodel ID'].iloc[0]) + '<span class="math-container">$$' + str(random_choice2['Adv ID'].iloc[0].astype(int)) + '$$</span>' + str(random_choice2['Image index'].iloc[0])
        random_choice3 = df2[(df2['Maker name'] != index[0]) | (df2['Model name'] != index[1]) | (abs(df2['Registration year'] - index[2]) &gt;= 10) | (df2['Color'] != index[3])].sample()
        path3 = str(random_choice3['Maker name'].iloc[0]) + '/' + str(random_choice3['Registration year'].iloc[0].astype(int)) + '/' + str(random_choice3['Maker name'].iloc[0]) + '<span class="math-container">$$' + str(random_choice3['Model name'].iloc[0]) + '$$</span>' + str(random_choice3['Registration year'].iloc[0].astype(int)) + '<span class="math-container">$$' + str(random_choice3['Color'].iloc[0]) + '$$</span>' + str(random_choice3['Genmodel ID'].iloc[0]) + '<span class="math-container">$$' + str(random_choice3['Adv ID'].iloc[0].astype(int)) + '$$</span>' + str(random_choice3['Image index'].iloc[0])
        a = cv2.cvtColor(cv2.imread(path1), cv2.COLOR_BGR2RGB)
        p = cv2.cvtColor(cv2.imread(path2), cv2.COLOR_BGR2RGB)
        n = cv2.cvtColor(cv2.imread(path3), cv2.COLOR_BGR2RGB)
        if high_filter:              #TODO if only a single channel is used, then architecture has to be (_,_,1); is there a way to be channel size independent?
            for img in [a,p,n]:
                temp = 0.2989 * img[:,:,0] + 0.5870 * img[:,:,1] + 0.1140 * img[:,:,2]
                temp = temp - ndimage.gaussian_filter(temp,3)
                img[:,:,0] = temp
                img[:,:,1] = temp
                img[:,:,2] = temp
        if print_paths:
            print(path1)
            print(path2)
            print(path3)
        images_row.append([a,p,n])
    random.shuffle(images_row)
    tr, val = train_test_split(images_row, shuffle=True, test_size=test_set_perc+val_set_perc)
    val, te = train_test_split(val, shuffle=True, test_size=test_set_perc)
    images_tr.extend(tr)
    images_val.extend(val)
    images_te.extend(te)
return images_tr, images_val, images_te
#TODO add random_state?
train, val, test = triplets_generator(sample_lim=200) print(len(train)) print(len(train[0]))
def batch_generator(triplets, batch_size=32, augment=True): total_triplets = len(triplets) random.shuffle(triplets)
datagen = ImageDataGenerator(
    rotation_range=10,
    width_shift_range=0.05,
    height_shift_range=0.05,
    horizontal_flip=True,
    zoom_range=0.2
for i in range(0, total_triplets, batch_size):
    batch_triplets = triplets[i : i+batch_size]
    anchor_batch = []
    positive_batch = []
    negative_batch = []
    for triplet in batch_triplets:
        anchor, positive, negative = triplet
        anchor_image = anchor
        positive_image = positive
        negative_image = negative
        if augment:
            anchor_image = datagen.random_transform(anchor_image)
            positive_image = datagen.random_transform(positive_image)
            negative_image = datagen.random_transform(negative_image)
        anchor_batch.append(anchor_image)
        positive_batch.append(positive_image)
        negative_batch.append(negative_image)
    yield np.array(anchor_batch), np.array(positive_batch), np.array(negative_batch)
batch=6 print(len([next(batch_generator(train, batch))])) print(len([next(batch_generator(train, batch))][0])) print(len([next(batch_generator(train, batch))][0][0]))
def print_triplets(triplets): a, p, n = triplets
for i in range(len(a)):
    fig, axarr = plt.subplots(1,3, figsize=(10, 4))
    axarr[0].imshow(a[i])
    axarr[0].title.set_text('Anchor')
    axarr[1].imshow(p[i])
    axarr[1].title.set_text('Positive')
    axarr[2].imshow(n[i])
    axarr[2].title.set_text('Negative')
    plt.show()
print_triplets([next(batch_generator(train, 6))][0])
def get_embedding(input_shape, num_layers_to_unfreeze=25): base_model = EfficientNetB7(weights='imagenet', input_shape=input_shape, include_top=False, pooling='avg')
for i in range(len(base_model.layers)-num_layers_to_unfreeze):
    base_model.layers[i].trainable = False
embedding = keras.models.Sequential([
    base_model,
    Flatten(),
    Dense(512, activation='relu'),
    BatchNormalization(),
    Dropout(0.3),
    Dense(256, activation='relu'),
    Dropout(0.3),
    Dense(128, activation='relu'),
    Dense(128)
], name='Embedding')
return embedding
input_shape = (300, 300, 3)
embedding = get_embedding(input_shape) embedding.summary()
@keras.saving.register_keras_serializable() class DistanceLayer(Layer): def init(self, kwargs): super().init(kwargs)
@tf.function
def call(self, anchor, positive, negative):
    ap_distance = tf.reduce_sum(tf.square(anchor - positive), -1)
    an_distance = tf.reduce_sum(tf.square(anchor - negative), -1)
    return ap_distance, an_distance
anchor_input = Input(name='anchor', shape=input_shape) positive_input = Input(name='positive', shape=input_shape) negative_input = Input(name='negative', shape=input_shape)
distances = DistanceLayer()( embedding(preprocess_input(anchor_input)), embedding(preprocess_input(positive_input)), embedding(preprocess_input(negative_input)) )
siamese_net = Model( inputs=[anchor_input, positive_input, negative_input], outputs=distances )
@keras.saving.register_keras_serializable() class SiameseModel(Model): def init(self, siamese_net, margin=0.5): super().init() self.siamese_net = siamese_net self.margin = margin self.loss_tracker = Mean(name='loss') self.accuracy_tracker = Mean(name='accuracy')
@tf.function
def call(self, inputs):
    return self.siamese_net(inputs)          #WTF
def train_step(self, *args, **kwargs):
    if keras.backend.backend() == &quot;jax&quot;:                   #TODO
        return self._jax_train_step(*args, **kwargs)
    elif keras.backend.backend() == &quot;tensorflow&quot;:
        print('TF')
        return self._tensorflow_train_step(*args, **kwargs)
    elif keras.backend.backend() == &quot;torch&quot;:               #TODO
        return self._torch_train_step(*args, **kwargs)
def _tensorflow_train_step(self, data):
    print(data)
    print(len(data))
    data = data[0]
    with tf.GradientTape() as tape:
        loss = self._compute_loss(data)#[0])
    gradients = tape.gradient(loss, self.siamese_net.trainable_weights)
    self.optimizer.apply_gradients(
        zip(gradients, self.siamese_net.trainable_weights)
    self.loss_tracker.update_state(loss)
    accuracy = self._compute_accuracy(data)#[0])               #WTF
    self.accuracy_tracker.update_state(accuracy)
    return {'loss': self.loss_tracker.result(),
            'accuracy': self.accuracy_tracker.result()}
def test_step(self, data):
    data = data[0]    #WTF
    loss = self._compute_loss(data)#[0])                       #WTF
def _compute_loss(self, data):
    ap_distance, an_distance = self.siamese_net(data)
    loss = ap_distance - an_distance
    loss = tf.maximum(loss + self.margin, .0)
    return loss
def _compute_accuracy(self, data):
    accuracy = tf.reduce_mean(tf.cast(ap_distance &lt; an_distance,
                                      tf.float32))
    return accuracy
@property
def metrics(self):
    return [self.loss_tracker, self.accuracy_tracker]
def get_config(self):
    base_config = super().get_config()
    config = {
        'siamese_net': keras.saving.serialize_keras_object(self.siamese_net),
        'margin': keras.saving.serialize_keras_object(self.margin),
        'loss_tracker': keras.saving.serialize_keras_object(self.loss_tracker),
        'accuracy_tracker': keras.saving.serialize_keras_object(self.accuracy_tracker),
    return {**base_config, **config}
@classmethod
def from_config(cls, config):
    config['siamese_net'] = keras.saving.deserialize_keras_object(config.pop('siamese_net'))
    config['margin'] = keras.saving.deserialize_keras_object(config.pop('margin'))
    config['loss_tracker'] = keras.saving.deserialize_keras_object(config.pop('loss_tracker'))
    config['accuracy_tracker'] = keras.saving.deserialize_keras_object(config.pop('accuracy_tracker'))
    return cls(**config)
def train_model(model, train_triplets, epochs, batch_size, val_triplets, patience, delta=0.0001):
best_val_accuracy = 0
best_val_loss = float('inf')
temp_patience = patience
history = {
    'loss': [],
    'val_loss': [],
    'accuracy': [],
    'val_accuracy': []
train_steps_per_epoch = math.ceil(len(train_triplets) / batch_size)
val_steps_per_epoch = math.ceil(len(val_triplets) / batch_size)
for epoch in range(epochs):
    print(f'Epoch {epoch+1}/{epochs}')
    train_loss = 0.
    train_accuracy = 0.
    val_loss = 0.
    val_accuracy = 0.
    with tqdm(total=train_steps_per_epoch, desc='Training') as pbar:
        for batch in batch_generator(train_triplets, batch_size=batch_size):
            loss, accuracy = model.train_on_batch(batch)
            train_loss += loss
            train_accuracy += accuracy
            pbar.update()
            pbar.set_postfix({'Loss': loss, 'Accuracy': accuracy})
    with tqdm(total=val_steps_per_epoch, desc='Validation') as pbar:
        for batch in batch_generator(val_triplets, batch_size=batch_size):
            loss, accuracy = model.test_on_batch(batch)
            val_loss += loss
            val_accuracy += accuracy
            pbar.update()
    train_loss /= train_steps_per_epoch
    train_accuracy /= train_steps_per_epoch
    val_loss /= val_steps_per_epoch
    val_accuracy /= val_steps_per_epoch
    history['loss'].append(train_loss)
    history['accuracy'].append(train_accuracy)
    history['val_loss'].append(val_loss)
    history['val_accuracy'].append(val_accuracy)
    print(f'\nTrain Loss: {train_loss:.4f}, Train Accuracy: {train_accuracy:.4f}')
    print(f'Validation Loss: {val_loss:.4f}, Validation Accuracy: {val_accuracy:.4f}\n')
    if val_accuracy &gt; best_val_accuracy:
        best_val_accuracy = val_accuracy
        model.layers[0].layers[3].save_weights('best_model.weights.h5')
    if val_loss - best_val_loss &gt; delta:
        temp_patience -= 1
        if temp_patience == 0:
            print('Early stopping: Validation loss did not improve.')
            break
    else:
        best_val_loss = val_loss
return model, history
siamese_model = SiameseModel(siamese_net) siamese_model.jit_compile = False siamese_model.compile(optimizer=Adam(0.00001))
siamese_model, history = train_model(siamese_model, train_triplets=train, epochs=200, batch_size=64, val_triplets=val, patience=3)
Rob99
