I watched this 3Blue1Brown video series explaining who backpropagation works, then I decided to implement it by creating the neural network described in the series (I used The MNIST dataset for training and testing). Here it is :
import pickle
import numpy as np
Loading Test Data
def load_test_data(): with open('data/test/test_labels.pkl','rb') as f: labels = pickle.load(f)
with open('data/test/test_images.pkl','rb') as f:
    images = pickle.load(f)
return list(zip(images,labels))
Laoding Training Data
def load_training_data(): with open('data/labels.pkl','rb') as f: labels = pickle.load(f)
with open(f"data/images.pkl",'rb') as f:
class Neural_Network : def init(self): # The Neural Network Layers self.layer = [[],[],[],[]] self.layer[0] = np.zeros(784) self.layer[1] = np.zeros(16) self.layer[2] = np.zeros(16) self.layer[3] = np.zeros(10)
    # The Weight Matricies
    self.W = [[],[],[]]
    np.random.seed(0)  # Set seed for reproducibility
    # Xavier/Glorot Initialization
    self.W[0] = np.random.randn(16, 784) * np.sqrt(2/(784 + 16))  # Consider both input and output dimensions
    self.W[1] = np.random.randn(16, 16) * np.sqrt(2/(16 + 16))
    self.W[2] = np.random.randn(10, 16) * np.sqrt(2/(16 + 10))
    # Biases Vectors
    self.B = [[],[],[]]
    self.B[0] = np.zeros(16)
    self.B[1] = np.zeros(16)
    self.B[2] = np.zeros(10)
def _sigmoid(self,x):
    return 1 / (1 + np.exp(-x))
def _sigmoidP(self,x):
    return np.exp(-x)/((1+np.exp(-x))**2)
# The output layer that was supposed to be true
def y(self,label):
    a = np.zeros_like(self.layer[3])
    a[label] = 1
    return a
def test(self,test_data) :
    c = 0
    for i in range(len(test_data)):
        self.feedforward(test_data[i][0])
        if (np.argmax(self.layer[3]) == test_data[i][1]):
            c += 1
    acc = (c / len(test_data)) * 100
    return acc
#Uses Stochastic Gradient Descent
def train(self,training_data,epochs,eta):
    mb_size = 125
    for epoch in range(epochs):
        print(f"\nEpoch {epoch + 1} Starts \n")
        # Dividing The Training data into mini batches
        np.random.shuffle(training_data)
        mini_batches = [ training_data[k:k+mb_size]  for k in range(len(training_data)//mb_size)]
        for mini_batch in mini_batches:
            self.gradient_step(mini_batch,eta)
# caculate the gradient according to the mini batch, and update the weights and biases.
def gradient_step(self,mini_batch,eta):
    # Gradient Vector (For Mini Batch) Initilizing
    self.gw = [np.zeros_like(self.W[i]) for i in range(3)]
    self.gb = [np.zeros_like(self.B[i]) for i in range(3)]
    for image, label in mini_batch :
        # Gradient Vector for a single Training Example Intilization
        gw0 = [np.zeros_like(self.W[i]) for i in range(3)]
        gb0 = [np.zeros_like(self.B[i]) for i in range(3)]
        # Set the layer outputs
        self.feedforward(image)
        # Gradient of the activations, we will use it to backpropagate
        ga = 2*(self.layer[3]-self.y(label))
        # max index for weights and biases.
        i = 2
        # Note That since the activations and the parameters don't have the same index
        # so a layer with index i, coresponds to bias with index i-1
        while i>=0 :
            # Caculating Z
            z = self.W[i]@self.layer[i]+self.B[i]
            gw0[i] = np.outer(self._sigmoidP(z)*ga,self.layer[i])
            gb0[i] = self._sigmoidP(z)*ga
            # using ga to backpropagate
            ga = (self.W[i].T)@(self._sigmoidP(z)*ga)
            i = i-1
        # Accumilating all of the gradients
        self.gw = [self.gw[i] + gw0[i] for i in range(3)]
        self.gb = [self.gb[i] + gb0[i] for i in range(3)]
    # getting the average by diving by the number of training example
    self.gw = [self.gw[i] / len(mini_batch)  for i in range(3)]
    self.gb = [self.gb[i] / len(mini_batch)  for i in range(3)]
    self.W = [self.W[i] - eta * self.gw[i] for i in range(3)]
    self.B = [self.B[i] - eta * self.gb[i] for i in range(3)]
def feedforward(self,input):
    self.layer[0] = input
    # Using the neural Network to determine the wirtten degit
    for i in range(3):
        z = self.W[i] @ self.layer[i]
        z = z + self.B[i]
        self.layer[i+1] = self._sigmoid(z)
NN = Neural_Network()
NN.train(load_training_data(),25,0.005)
#NN.test(load_test_data())
The Problem I am having is that when I test it after training, the accuracy is 10%, I double checked the algorithm implementation and I didn't see any issues, The training data was also loaded Correctly, after that I tried playing with the number of epochs and learning rate, I tried with 100 epochs and 0.005 learning rate but it didn't work.
I tested the network with the training data and the accuracy was 89%.
why is that? What mistake am I making?
Here is a link to the full code and training data if you want to run it
