The explicit solution, the famous $\hat\beta_{OLS} = (X^TX)^{-1}X^Ty$ in statistics, is a piece of linear algebra that says what the best fit is, given a certain model. There is no commentary, however, about how good that fit is. The relationship between variables and the outcome could be curvy (nonlinear); there could be interactions between the variables, that the impact one variables has on the outcome depends on the values of other variables; the interactions could be curvy (interactions between nonlinear transformations of the variables). If you just stick a straight line (hyperplane for multiple linear regression) through the data, the fit might be quite poor and able to be improved upon.
There is an interesting paper out there that neural networks are just polynomial regressions, which is a particular form of linear regression that can be solved with the matrix solution, $\hat\beta_{OLS} = (X^TX)^{-1}X^Ty$. However, that requires explicit engineering of the polynomial features: which relationships are curved, which variables interact, and which interactions involve curvature. For better or for worse, neural networks do not require this. You just throw a bunch of neurons at the problem, with practitioners varying in how thoughtful they are about the exact architecture, and let the network figure out the relationship.
Being explicit in answering your question, neural networks offer a possible improvement in performance compared to more basic forms of linear regression (without interactions or nonlinear transformations of features), due to their high capacity for flexible modeling that the rigidity of hyperplanes do not allow. If you start allowing for complicated linear models involving interactions and curvature in the features, then linear regression could be more competitive, as Cheng et al (2018) argue.
REFERENCE
Cheng, Xi, et al. "Polynomial regression as an alternative to neural nets." arXiv preprint arXiv:1806.06850 (2018).
