Yesterday I gave a task to ChatGPT and noticed despite the clear step-by-step task to return the information from a simple table with 38 records, it stops to generate right response and after some back and fourth it returns me 15/16 records and I need to ask for to return me complete it for all records of table (table has multi columns):
please complete the task for all records of table. you return 15 out of 38 records.
an then it returns with increment of 1 records more than previous generated answer which was frustrating to chat like this and get still incomplete results.
At the end I did trick and I asked to start from end of table and merge the results!
- I'm curious why it the case is for doing the clear task incompletely? I was assuming maybe there is restriction to generate long answers but returning info of a table with 38 records should not be called long task in sense of length of generated return response?
- Are there some prompt engineering techniques I should now except for define the task step-by-step and use right vocab?
Note:
- I had a premium account while did this experiment and conversation.
- used model: GPT-4o
