I am trying to get started with pinns so i build this simple script to train an mlp using only the ode. The ode i am trying to solve is y = dy/dx. I am using numpy in this script and no other ml frameworks. Things I tried but didn't work:
  1. Tried relu and tanh
  2. Tried learning rate from 0.1 to 1e-6
  3. Tried Xavier and He weight initialisation and other methods
  4. Tried both numerical and analytical differentiation to find dydx
import numpy as np
from math import sqrt
import matplotlib.pyplot as plt
def tanh(x): return np.tanh(x)
def tanh_derivative(x): return 1 - np.tanh(x)**2
def relu(x): return np.maximum(0, x)
def relu_derivative(x): return np.where(x > 0, 1, 0)
activation_function = relu activation_function_derivative = relu_derivative
def initialize_adam(parameters): v = {} s = {}
for key in parameters.keys():
    v[key] = np.zeros_like(parameters[key])
    s[key] = np.zeros_like(parameters[key])
return v, s
def initialize(n1, n2, n3, n4):
W1 = np.random.uniform(-1/sqrt(n1),1/sqrt(n1),size = (n2, n1))
B1 = np.random.uniform(-0.5, 0.5, size=(n2, 1))
W2 = np.random.normal(-1/sqrt(n2),1/sqrt(n2),size = (n3, n2))
B2 = np.random.uniform(-0.5, 0.5, size=(n3, 1))
W3 = np.random.normal(-1/sqrt(n3),1/sqrt(n3),size = (n4, n3))
B3 = np.random.uniform(-0.5, 0.5, size=(n4, 1))
parameters = {'W1':W1,'W2':W2,'W3':W3,'B1':B1,'B2':B2,'B3':B3}
return parameters
def forward_propagation(A0, parameters:dict): W1 = parameters['W1'] W2 = parameters['W2'] W3 = parameters['W3'] B1 = parameters['B1'] B2 = parameters['B2'] B3 = parameters['B3']
Z1 = np.dot(W1, A0) + B1
A1 = activation_function(Z1)
Z2 = np.dot(W2, A1) + B2
A2 = activation_function(Z2)
Z3 = np.dot(W3, A2) + B3
Y_hat = Z3 #Y_hat
forward = {'Z1':Z1,'A1':A1,'Z2':Z2,'A2':A2,'Z3':Z3,'Y_hat':Y_hat}
return forward
def back_propagation(A0,Y,forward:dict,parameters:dict,dydx): W1 = parameters['W1'] W2 = parameters['W2'] W3 = parameters['W3']
A1 = forward['A1']
A2 = forward['A2']
Y_hat = forward['Y_hat']
Z1 = forward['Z1']
Z2 = forward['Z2']
Z3 = forward['Z3']
network_initial_condtion = forward_propagation(A0[0][0]*np.ones_like(A0), parameters) #netowrk ouput at x = A0[0][0]
Y0 = network_initial_condtion['Y_hat']
initial_condition_error = Y[0] - Y0
ode_error = dydx - Y_hat
l1 = 1 #weight of ode error
l2 = 1 #weight of intitial condition error
m = A0.shape[1]
dldy = (1/m) * (l1*ode_error + l2*initial_condition_error)
dldz3 = dldy
dldw3 = np.dot(dldz3, np.transpose(A2))
dldb3 = np.sum(dldz3,axis=1, keepdims=True)
dlda2 = np.dot(W3.T, dldz3)
dldz2 = dlda2 * activation_function_derivative(Z2)
dldw2 = np.dot(dldz2, np.transpose(A1))
dldb2 = np.sum(dldz2,axis=1, keepdims=True)
dlda1 = np.dot(W2.T, dldz2)
dldz1 = dlda1 * activation_function_derivative(Z1)
dldw1 = np.dot(dldz1, np.transpose(A0))
dldb1 = np.sum(dldz1,axis=1, keepdims=True)
backward = {'W1':dldw1,'B1':dldb1,'W2':dldw2,'B2':dldb2,'W3':dldw3,'B3':dldb3}
return backward
def gradient(forward:dict,parameters:dict): W1 = parameters['W1'] W2 = parameters['W2'] W3 = parameters['W3']
Z1 = forward['Z1']
Z2 = forward['Z2']
# graidents in relation to network outpout Y_hat
dydy = np.ones_like(Y_hat )
dydz3 = dydy
dyda2 = np.dot(W3.T, dydz3)
dydz2 = dyda2 * activation_function_derivative(Z2)
dyda1 = np.dot(W2.T, dydz2)
dydz1 = dyda1 * activation_function_derivative(Z1)
dydx = np.dot(W1.T, dydz1)
return dydx
def update_adam(parameters, grads, v, s, t, learning_rate=None, beta1=0.9, beta2=0.999, epsilon=1e-8): v_corrected = {} s_corrected = {}
    v[key] = beta1 * v[key] + (1 - beta1) * grads[key]
    s[key] = beta2 * s[key] + (1 - beta2) * (grads[key] ** 2)
    v_corrected[key] = v[key] / (1 - beta1 ** t)
    s_corrected[key] = s[key] / (1 - beta2 ** t)
    parameters[key] -= learning_rate * (v_corrected[key] / (np.sqrt(s_corrected[key]) + epsilon))
return parameters, v, s
def mean_squared_error(Y_hat, Y): mse = np.mean((Y_hat - Y) ** 2) return mse
def train(A0, Y, epochs, a, n1, n2, n3, n4):
parameters = initialize(n1, n2, n3, n4)
v,s = initialize_adam(parameters)
for i in range(1, epochs + 1):
    forward = forward_propagation(A0, parameters)
    dydx = gradient(forward,parameters)
    gradients = back_propagation(A0,Y,forward,parameters, dydx)
    parameters,v,s = update_adam(parameters, gradients, v, s, i, learning_rate=a)
    if i % 100 == 0 or i==1:
        Y_hat = forward['Y_hat'].flatten()
        mse = mean_squared_error(Y_hat, Y)
        print(f'Epoch: {i}/{epochs} MSE: {mse}')
return Y_hat.flatten()
n1 = 1 #input n2 = 18 #hidden 1 n3 = 18 #hidden 2 n4 = 1 #output
X = np.linspace(0, 3, 200)
Y = np.exp(X) #ode solution
m = len(X) A0 = X.reshape((n1, m))
epochs = 1000 a = 1e-5 #learning rate
Y_hat = train(A0, Y, epochs, a, n1, n2, n3, n4)
plt.plot(X,Y,label ='ODE solution') plt.plot(X,Y_hat,label='PINN solution') plt.grid() plt.legend() plt.show()
