prompt |
string or array |
Optional |
<\|endoftext\|> |
The prompt or prompts to generate completions for, encoded as a string, or array of strings. <\|endoftext\|> is the document separator that the model sees during training, so if a prompt isn't specified the model generates as if from the beginning of a new document. |
max_tokens |
integer |
Optional |
16 |
The maximum number of tokens to generate in the completion. The token count of your prompt plus max_tokens can't exceed the model's context length. Most models have a context length of 2048 tokens (except for the newest models, which support 4096). |
temperature |
number |
Optional |
1 |
What sampling temperature to use, between 0 and 2. Higher values mean the model takes more risks. Try 0.9 for more creative applications, and 0 (argmax sampling) for ones with a well-defined answer. We generally recommend altering this or top_p but not both. |
top_p |
number |
Optional |
1 |
An alternative to sampling with temperature, called nucleus sampling, where the model considers the results of the tokens with top_p probability mass. So 0.1 means only the tokens comprising the top 10% probability mass are considered. We generally recommend altering this or temperature but not both. |
logit_bias |
map |
Optional |
null |
Modify the likelihood of specified tokens appearing in the completion. Accepts a json object that maps tokens (specified by their token ID in the GPT tokenizer) to an associated bias value from -100 to 100. You can use this tokenizer tool (which works for both GPT-2 and GPT-3) to convert text to token IDs. Mathematically, the bias is added to the logits generated by the model prior to sampling. The exact effect varies per model, but values between -1 and 1 should decrease or increase likelihood of selection; values like -100 or 100 should result in a ban or exclusive selection of the relevant token. As an example, you can pass {"50256": -100} to prevent the <|endoftext|> token from being generated. |
user |
string |
Optional |
A unique identifier representing your end-user, which can help monitoring and detecting abuse |
n |
integer |
Optional |
1 |
How many completions to generate for each prompt. Note: Because this parameter generates many completions, it can quickly consume your token quota. Use carefully and ensure that you have reasonable settings for max_tokens and stop. |
stream |
boolean |
Optional |
False |
Whether to stream back partial progress. If set, tokens are sent as data-only server-sent events as they become available, with the stream terminated by a data: [DONE] message. |
logprobs |
integer |
Optional |
null |
Include the log probabilities on the logprobs most likely tokens, as well the chosen tokens. For example, if logprobs is 10, the API will return a list of the 10 most likely tokens. The API will always return the logprob of the sampled token, so there might be up to logprobs+1 elements in the response. This parameter cannot be used with gpt-35-turbo. |
suffix |
string |
Optional |
null |
The suffix that comes after a completion of inserted text. |
echo |
boolean |
Optional |
False |
Echo back the prompt in addition to the completion. This parameter cannot be used with gpt-35-turbo. |
stop |
string or array |
Optional |
null |
Up to four sequences where the API will stop generating further tokens. The returned text won't contain the stop sequence. For GPT-4 Turbo with Vision, up to two sequences are supported. |
presence_penalty |
number |
Optional |
0 |
Number between -2.0 and 2.0. Positive values penalize new tokens based on whether they appear in the text so far, increasing the model's likelihood to talk about new topics. |
frequency_penalty |
number |
Optional |
0 |
Number between -2.0 and 2.0. Positive values penalize new tokens based on their existing frequency in the text so far, decreasing the model's likelihood to repeat the same line verbatim. |
best_of |
integer |
Optional |
1 |
Generates best_of completions server-side and returns the "best" (the one with the lowest log probability per token). Results can't be streamed. When used with n, best_of controls the number of candidate completions and n specifies how many to return – best_of must be greater than n. Note: Because this parameter generates many completions, it can quickly consume your token quota. Use carefully and ensure that you have reasonable settings for max_tokens and stop. This parameter cannot be used with gpt-35-turbo. |
