The KL divergence between two distributions is: \begin{equation} \int \mathbf{p}(x;\theta_{1}) \; log \frac{\mathbf{p}(x;\theta_{1})}{\mathbf{p}(x;\theta_{2})} \nu(dx) \\ \end{equation}
If the expression $\mathbf{p}(x;\theta)$ is specified by its canonical parameters, we can simply calculate the KL divergence using the expressions of $\mathbf{p}$. However in the case of (conditional: deleted) distributions (where random vector $\mathbf{x}$ appears: added) $\mathbf{p}(y|x;\theta_{1})$, how would one find the KL divergence? Would it require sampling many $x$'s to estimate this value?
As a concrete example, in the case of Logistic regression we have for some random initialized $\theta_0$: \begin{equation} \mathbf{p}(y = 1|x;\theta_0) = \frac{1}{1+e^{-\theta_0^{\intercal}x}} \quad\quad \mathbf{p}(y = 0|x;\theta_0) = \frac{e^{-\theta_0^{\intercal}x}}{1+e^{-\theta_0^{\intercal}x}}. \end{equation}
and another one with $\theta_1$: \begin{equation} \mathbf{p}(y = 1|x;\theta_1) = \frac{1}{1+e^{-\theta_1^{\intercal}x}} \quad\quad \mathbf{p}(y = 0|x;\theta_1) = \frac{e^{-\theta_1^{\intercal}x}}{1+e^{-\theta_1^{\intercal}x}}. \end{equation}
Now we want to compute the improvement of model $\theta_1$ over $\theta_0$, using KL divergence:
\begin{align*} D(P(y|x;\theta_0)|P(y|x;\theta_1)) &= \frac{1}{1+exp(-\theta_0^{\intercal}x)} \cdot ln \biggl( \frac{1+exp(-\theta_{1}^{\intercal}x)}{1+exp(-\theta_0^{\intercal}x)} \biggr) \\ &+\; \frac{exp(-\theta_0^{\intercal}x)}{1+exp(-\theta_0^{\intercal}x)} \cdot ln \biggl( \frac{1+exp(-\theta_0^{\intercal}x)}{exp(-\theta_0^{\intercal}x)} \cdot \frac{exp(-\theta_{1}^{\intercal}x)}{1+exp(-\theta_{1}^{\intercal}x)} \biggr).\\ \end{align*}
How would one evaluate $exp(-\theta_0^{\intercal} x)$? Would you sample the values of x if possible? Now suppose you have many examples of $x$ available, ie in a training set, would it be "fair" to sample from the training set to evaluate $D$?
edit
Removed the "conditional distribution", and replaced it with expressions where random vector $\mathbf{x}$ makes an appearance in the definition. There is a comparable question here https://math.stackexchange.com/questions/3016421/confused-by-kullback-leibler-on-conditional-probability-distributions. But in that case the accepted answer compute the expected value of the KL divergence wrt the distribution $P(x)$. But in my case I do not have this distribution $P(x)$, only a dataset $\{(x_1,y_1),..,(x_n,y_n)\}$. I can evaluate the quantitity $D(P(y|x;\theta_0)|P(y|x;\theta_1))$ for every $(x_i,y_i)$ in the dataset, but how would you compute the expecatation: \begin{equation} E_{x \sim P(x)}[ D(P(y|x;\theta_0)|P(y|x;\theta_1)) ] \end{equation} without this $P(x)$?. The naive method is to assume $P(x)$ is a uniform distribution, at which point the expectation is just the average... but it seems like a better solutions is available somewhere. The closest I can find is this: https://www.tsc.uc3m.es/~fernando/bare_conf3.pdf, which builds a CMF from the data itself.
xiaolingxiao
  • 111
The distribution being conditional or not does not change the notion of KL divergence.
Indeed, given $p(x) \sim N(\mu_1, \sigma_1^2)$ and $q(x) \sim N(\mu_2, \sigma_2^2)$, the KL can be estimated in closed form.
However, the KL between $p(y|x) \sim N(\mu_1, \sigma_1^2)$ and $q(y|x) \sim N(\mu_2, \sigma_2^2)$ shares the same closed form with the previous one
The only thing you have to know is what family of distribution does the conditional probability falls in
And in your example, $x$ is the conditioning, thus you are saying that "you know a point estimate $\theta$ and a point estimate $x$", which means that that term can be estimated in closed form as it's a product of two point estimates, aka numbers/vectors
the solution of you (last) formulation is straightforward, as $P(y|x,\theta) ~ Bernoulli$, and the kl of discrete distribution is trivial
The only thing you have to do is to compute the KL sample wise, and then average the KL over all the samples
What you will get is a unbiased monte carlo estimate of your overall KL
Alberto
  • 2,863
