import torch
from transformers import AutoTokenizer, AutoModelForSequenceClassification
# Load tokenizer and model
tokenizer = AutoTokenizer.from_pretrained("Maltehb/danish-bert-botxo")
model = AutoModelForSequenceClassification.from_pretrained("Maltehb/danish-bert-botxo")
# Text to classify
text = "Det er en god dag"
# Tokenize input text
inputs = tokenizer(text, return_tensors="pt")
# Forward pass through the model
outputs = model(**inputs)
# Get predicted probabilities for each class
probs = torch.softmax(outputs.logits, dim=1).detach().numpy()
print(probs)
# Predicted label
predicted_label = "positive" if probs[0][1] > probs[0][0] else "negative"
print("positive prob:", probs[0][1])
print("negative prob:", probs[0][0])
print(f"The sentiment of the text '{text}' is {predicted_label}.")
output:
$ python temp.py
Some weights of BertForSequenceClassification were not init
ialized from the model checkpoint at Maltehb/danish-bert-bo
txo and are newly initialized: ['classifier.bias', 'classifier.weight']
You should probably TRAIN this model on a down-stream task to be able to use it for predictions and inference.
[[0.43838173 0.5616182 ]]
positive prob: 0.5616182
negative prob: 0.43838173
The sentiment of the text 'Det er en god dag' is positive.
I am surprised to read that Some weights of BertForSequenceClassification were not init ialized from the model checkpoint at Maltehb/danish-bert-bo txo and are newly initialized: ['classifier.bias', 'classifier.weight'].
If I understood it correctly, Maltehb/danish-bert-bo txo is an already trained model, so I shouldn't have to train it again. So why were some of the weights not initialized from the model checkpoint?
