I have a batched input to GATv2Conv with node matrix of shape [batch_sz , num_nodes , node_feature_dim] , but the GATv2Conv accepts input of dim 2 ,searching through the internet , I found some solution ... (not the one I want)
data_list = [Data(x= torch.squeeze(torch.index_select(x, dim= 0, index = torch.tensor([idx]))) ,
                              edge_index= self.edge_indices ,
                              edge_attr= torch.squeeze(torch.index_select(adj_mats[i], dim= 0, index = torch.tensor([idx]))))
                         for idx in range(self.batch_sz)]
            batch  = Batch.from_data_list(data_list)
But using above solution , the distinction between graphs got lost , becuase : batch.x.shape gave [batch_sz * num_nodes , node_feature_dim]...
It simply put all nodes of all graphs in one single graphs.. Now there is shared calculations between different graphs , which is strictly undesirable... As when applying some graph pooling layer, I don't know which nodes belonged to which graph....
Pls suggest some fix for this issue ...
Thanks in advance
For efficiency reasons, it is the standard for graph learning libraries to use the format [n_batches x num_nodes, node_feature_dim], instead of having batches in an extra batch dimension. Specifically, the different graphs of a batch are transformed into a single large graph with disjoint subgraphs. However, because there is no connection between any two graphs of the batch, neighborhood operations like message-passing will not leak information into different graphs of the batch. This is not true for global graph operations, such as pooling. Such operations require a batch-index as an additional input. The batch-index maps each node onto its batch index. In the following, $f$ is a global graph operation (set operation), $N$ is note number of graphs $\mathcal{G}$ in your batch.
$$ X = \{ f\left(\mathcal{G}_i\right) : \forall i \in [0,..,N] \} $$
Each result will only contain information from within the respective batch. In the Batch class that you are using, according to the documentation, there is a batch field that tells you which nodes belong to which graph:
In addition, single graphs can be identified via the assignment vector batch, which maps each node to its respective graph identifier.
For more on graph batching in general here is a colab notebook that contains some nice demo code.
Chillston
  • 1,878
  • 13
