I'm interested in how text to image models like Midjourney and Dall-E work, where you enter a text prompt and get as output some images. I started reading some papers on it and stumbled upon "Denoising Diffusion Probabilistic Models" - https://arxiv.org/pdf/2006.11239.pdf.
It describes the diffusion process and how there is a sequence of random variables, $x_t$, moving between them through a Markov chain, etc.
But neither in this paper nor in any others did I find an explanation for how the training data (which I assume is tuples of images and accompanying text) is actually used. How does it play a role in the likelihood/ objective function?
Rohit Pandey
  • 161
I have recently taken a seminar on a similar let me explain you in brief,
The complete end-to-end process has 3 steps while inferencing:
  • Text Encoding (using CLIP Model)
  • Image Information Creator (Unet + Scheduler)
  • Image Decoder (Auto Encoder)
  • Text Encoding: These Encoding models are trained on Image to caption Database or similar, They are good in matching Text with Image data.
  • Image Information Creator (Unet + Scheduler): The Unet model is trained to Predict the noisy Part of the Image.
  • For the end-to-end process of Image generation. An attention module is introduced which will attend to the Text Embeddings and change the Image pixels in that direction
  • Scheduler: Scheduler will add noise to image after each iteration for variation of pixels. enter image description here
  • VAE: All the processes mentioned above are in latent space for faster convergence and speed, VAE later converts the latent image to a pixel image.
Hiren Namera
  • 785
  • 20
