No, adding an additional mask to the residual connections or the linear layer isn't necessary. The masking is crucial solely for the attention mechanism. Implementing a mask in the residual connections or the linear layer would only reduce dimensionality and overly constrain the model's outputs. Remember, for the final output, it's essential that the model has full contextual information. Zeroing a value at any step would make the model less efficient by causing it to lose information.
It's important to note that even within the attention mechanism, the input data is already being utilized in the attention computation. This is evident after the masking of the attention weights, where the matrix $QK^T$ is projected again with the
$V$ matrix, which is equal to $W_VX$. Where $X$ is the input data. Thus, worrying about retaining the mask output is unnecessary. Additionally, when multiplying with the $V$ matrix, you're already losing the lower triangular matrix. From that point on, adding the initial input doesn't pose an issue.
Another crucial aspect to consider is the significance of the residual layers. Without them, the positional information from the Positional Encoding (PE) would rapidly diminish, making it vital to retain these layers. So, even if, for some reason, it affects the property of not seeing future tokens (which it doesn't), you would still want to maintain the residual connections.
