I am trying to accomplish the reverse of the typical MNIST in machine learning using a GAN - instead of predicting a number from an image of a digit, I want to reconstruct an image of a digit from a number. The traditional GAN, however, isn't designed for this use case, as it is designed to generate images similar to training data directly without being given an input. One way to work around this issue that I've thought of is to take a train feature digit, connect it to a densely-connected layer Dense(784), reshape it to (28 x 28 x 1), and then proceed with the generator as one usually does for a GAN. However, this seems like "fooling" the neural network to make up weights out of thin air, and I doubt this would work properly.
How can I modify a GAN so that it takes single-digit inputs without resorting to the aforementioned approach?
