I am trying to train a Q learning agent on the following game: The states are parametrised by an integer $S \geq 0$ (representing the sum of the previous die rolls). In each step the player can choose to roll a die or quit the game. Whenever the player rolls a six, the game terminates with 0 reward. Otherwise, the player updates $S \to S+$number of eyes. If the player chooses to terminate, they receive $S$ as a reward. The most natural strategy is to choose a threshold $t$ and decide to roll the die whenever $S \leq t$. I believe the optimal $t$ (ie maximising expected value) is $1+2+3+4+5 = 15$. In simulations, the $t=15$ strategy achieves an expected value of around 6. A standard Q learning agent achieves 2.1 reward and a double Q agent (as in the original Hasselt paper) around 2.5. Is such a low performance to be expected? Is there a variant of Q learning that would perform much better? Or did I probably make a mistake in the implementation or choice hyperparameters (learning rate= 0.6, training episodes = 10000, $\gamma$ = 0.95)?
In short, you do have a problem with your hyperparameters, but also single-step Q-Learning appears to struggle a lot with this simple looking environment. The environment seems simple because it is possible to solve it quickly analytically. However, Q Learning does not and cannot analyse the environment, and must learn through trial and error.
This is the optimal action value table for states 0 through 20. It can be calculated quickly (in a fraction of a second using Python) and to high accuracy using value iteration.
State Roll Quit Optimal Choice
0 6.154 0.000 r
1 6.532 1.000 r
2 6.933 2.000 r
3 7.359 3.000 r
4 7.810 4.000 r
5 8.289 5.000 r
6 8.798 6.000 r
7 9.340 7.000 r
8 9.914 8.000 r
9 10.522 9.000 r
10 11.161 10.000 r
11 11.853 11.000 r
12 12.588 12.000 r
13 13.361 13.000 r
14 14.167 14.000 r
15 15.000 15.000 r,q
16 15.833 16.000 q
17 16.667 17.000 q
18 17.500 18.000 q
19 18.333 19.000 q
20 19.167 20.000 q
Any policy with an expected score around $6.1$ from $S=0$ should be close to optimal.
So, what is wrong with your Q-Learning attempt?
The main problem impacting Q-learning is the high variance for Roll action, especially for higher state numbers. This requires a low learning rate, otherwise the "jitter" from the most recent experiences is strong enough that the correct policy never settles. Imagine that you had close to correct action value for $S=14$, with $\hat{q}(14,roll) = 14.2$. And a learning rate of $\alpha = 0.1$. What would that update to if you chose $roll$ in state $14$, and the die roll was a 6? It would change to $\hat{q}(14,roll) = 12.8$ . . . changing for a while what the greedy action choice is.
If you make the learning rate low to combat this, you will need more iterations to converge. A lot more.
The high variance is also a problem when combined with the relatively close optimal values between $roll$ and $quit$ actions around the break-even point. Choosing to roll in $S=14$ is only around 1% better expected return than choosing to quit, and simlar for choosing to quit instead of roll in $S=16$. This should not prevent learning agents getting close to the best scores (after all it is only 1% difference in a later expected value, even if the agent gets it wrong), but you will often see incorrect action choices learned in the $S=12$ to $S=18$ region for that reason.
In addition, a minor thing is that the discount factor $\gamma$ is not a learning hyperparameter. It is part of the problem definition. This changes slightly when considering approximation functions - it is common to pick a value like 0.99 to help stabilise long-term predictions. In your case I think the correct value is $\gamma = 1$
Using single-step Q learning, without any adjustments, I found the following hyper-parameters performed well:
- Number of episodes $N = 1000000$
- Learning rate $\alpha = 0.01$
- Epsilon randomness $\epsilon = 0.25$
This took around 20 seconds to calculate, and was not perfect (typically it will quit on 13+, but otherwise is consistent). That extra time is the cost of not knowing the model or allowing for any of its traits, having to discover the reliability of quitting versus the variance of rolling - separately at each state (because there is no generalisation from a function approximator). Increasing to $N = 10000000$ and decreasing $\alpha = 0.005$ takes over 3 minutes, but gets close to perfect values.
I'm not sure what variants of Q Learning could help. Double Q learning is not going to help much, because that is for dealing with maximisation bias which is not really a problem here. Potentially n-step Q learning could help by making multiple updates at once, which should counter the slow learning rate.
A quick fix to the problem in single-step Q learning is to have a learning rate schedule. If you arrange to exponentially decay learning rate from $1.0$ to $0.005$ over the course of all episodes, then you can reduce the episode count down to 100,000 and get pretty good results. This is because the high learning rates quickly converge on the deterministic returns from choosing $quit$ action, and then the lower learning rates later on allow the action values to stabilise for the $roll$ action.
- 33,739
- 3
- 47
- 66
